Home > Forums > Software User Forums > SU2
ParMetis running very slow with increasing number of processors
Old   April 10, 2018, 07:19
Default ParMetis running very slow with increasing number of processors
sam
aeroiitkgp is on a distinguished road
I have a grid size of 3 million cell volumes. It took just few seconds to partition using 24 cores, but took almost 15 mins to partition with 240 cores. My machine is a Linux cluster running redhat with 24 cores in each node. I have attached the configuration file
I also tried a37 million mesh with 480 processors which took 3 hours to partition. And it does partitioning for each case
Is there any way to save the partition file so that it can be used for other cases? Also can distance file for SA model be saved to be used in other cases? Kindly help me resolve this issuses.
aeroiitkgp is offline   Reply With Quote
Old   April 23, 2018, 11:45
Tim Albring
talbring is on a distinguished road
Actually it shouldn't take that long for the partitioning ... are you sure your cluster is properly set up and there is a high-speed connection between the nodes (like e.g. infiniband)?
Developer Director @ SU2 Foundation
Get involved:
talbring is offline   Reply With Quote
Old   April 23, 2018, 11:57
sam
Yes our cluster has an infiniband link. We regularly use parallel programs and they run very efficiently.
But I am not sure what is slowing down SU2 Partioning. If you can guide on what should I check in order to ensure that everything is ok with cluster or SU2, it would be useful.
Also is there any way to save partitioning file?
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 05:13
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 10:42
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 10:01
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 08:59
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
