Ahmed
Rep Power: 8 ![]() |
Hello Everyone
I am using SU2 v5 for parallel computations on windows but it doesn`t generate flow.vtk and output files for post-processing. How can I get these files? Thanks very much |
Osman Mirza Demircan
Rep Power: 9 ![]() |
You have to run SU2_SOL in order to get output files after parallel computations.
Osman Mirza Demircan |
Heather Kline
Rep Power: 14 ![]() |
This should be done automatically when using the parallel_computation.py script - I don't use this on windows, if there is a windows-specific issue another user will have to weigh in. I do know that many people (myself included) have found setting up for parallel on windows to be challenging, so you may also want to check the output to make sure that the simulation completed successfully.
You will also need to make sure that OUTPUT_FORMAT is set to PARAVIEW (it is TECPLOT by default) |
Shyam Sunder
Rep Power: 11 ![]() |
Dear All
I tried reading the Tecplot data from SU2 6.0.0 using Paraview but it gives error, which I think, is related to the header line in the file. "PointID" "x" "y" "z" "Density" "X-Momentum" "Y-Momentum" "Z-Momentum" "Energy" etc. The error says: 'The record type x found in the file is unknown' I tried Visit as well but that also gives the error. Somebody please help. Thanks and Regards Shyam |
Wally Maier
Rep Power: 7 ![]() |
Hi Shyam,
I have unfortunately run into this problem as well. I would suggest rerunning SU2_SOL with OUTPUT_FORMAT= PARAVIEW in your config. Hope this helps, Wally |
Amit
Rep Power: 13 ![]() |
Hi Shyam and Wally,
Just change the extension of Tecplot output file from .dat to .tec and read in ParaView by selecting Tecplot(visit) option. It should work. Let me know. Last edited by aero_amit; January 25, 2020 at 02:00. |
Shyam Sunder
Thanks Wally...Your suggestion worked.
Thanks Amit. I tried changing the extension from .dat to .tec, Paraview reads the file but still gives the same error as earlier. I could not find the Tecplot(Visit) option. The two options are: Tecplot Files and Tecplot Table. Please have a look. I am using Paraview 5.4.1. Thanks again Wally and Amit |
Amit
Hi Ssyadav,
I am using paraview 5.2.0 (Ubuntu 16.04). For example, I change flow.dat to flow.tec and than File - > Open - > flow.tec, it will ask Open Data with (a dialog box). You have to select Tecplot Files (Visit) option. Than select the mesh and point Arrays. That's all to it. Best Amit |
Unsteady simulation solution files in parallel | gunnersnroses | SU2 | 1 | December 15, 2015 13:28 |
RNG diverged during the analysis the flow over a multi element airfoil, why? | s.m | OpenFOAM Running, Solving & CFD | 0 | August 5, 2013 08:39 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 09:34 |
Output files are gibberish | ozzythewise | OpenFOAM Running, Solving & CFD | 1 | March 14, 2011 13:43 |
Input and output files | Vyatscheslav | CFX | 0 | September 15, 2005 11:40 |
