March 21, 2018, 06:49 |
Finer mesh input set file for Onera M6 turbulent model
surya
Rep Power: 8 |
I am very new to CFD/SU2. I am looking for a finer mesh input file for onera M6 turbulence simulation model. I can see that the current SU2 file has 43,008 hexahedral elements and 46,417 nodes. I am looking forward to generate a SU2 file around 50 million nodes. Though there are methods on how to generate it using external tool am not able to get them working as they are propreitary. ( Similar to the square.py, is anyone having a source file for onera M6 simulation? Else, kindly suggest the simplest way of generating this with opensource. Last edited by ucmsuri; March 29, 2018 at 06:35. |
March 29, 2018, 05:59 |
Unable to convert CGNS to SU2
surya
Rep Power: 8 |
Hello, Inorder to get finer and denser mesh for Onera M6 wing, I am trying the following procedure and am stuck in my last step when converting CGNS to SU2 with mis-match in the markers.
Procedure: 1. Downoaded the grid generator from NASA's TRM website (https://turbmodels.larc.nasa.gov/one...ics_grids.html) 2. Generated a wing prism model in *.ugird format. 3. Used the aflr3_to_cgns using the cgnstools (https://gitlabext.iag.uni-stuttgart....ools/utilities) 4. Changed the input mesh format to CGNS in turb_ONERAM6.cfg and tried generating *.SU2 output file but this is failing due to mis-match in markers. Please find the error in the attached pic. |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 18:34 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 22:53 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 18:18 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 04:23 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
