Home > Forums > Software User Forums > SU2
Modification of a cfg parameter in restart
Old   March 19, 2018, 06:01
Question Modification of a cfg parameter in restart
Eran Arad
Arad is on a distinguished road
I shall appreciate a suggestion:
A common situation in direct solution: You restart from a previous solution
(where say, AOA = 0.) aiming at the solution of different condition (say AOA=4.0).
This does not happen: The restart value overwrites the new cfg data. How can this be avoided?
An example: Setting the cfg file:
RESTART_SOL= YES
AOA= 4.0
SOLUTION_FLOW_FILENAME= solution_flow.dat
#(that was obtained before with AOA=0)
Starting SU2_CFD (serial or parallel mode) the output printout acknowledges the cfg:
"Angle of attack (AoA): 4 deg, and angle of sideslip (AoS): 0 deg."
But then you get the following warning:
"WARNING: AoA in the solution file (0.000 deg.) +
AoA offset in mesh file (0.000 deg.) = 0.000 deg."
and the code is running with the AOA of the solution (restart) file (0 in this case).
The warning is issued by SU2/SU2_CFD/src/solver_structure.cpp:2768:
issued by:
if ((config->GetAoA() != AoA_)
Actually the overwriting happens in solver_structure.cpp:2567:
AoA_ = Restart_Meta[0];
Is there a way to prevent this overwriting (other than modify the cpp file)?
Thanks,
Eran Arad
Arad is offline   Reply With Quote
Old   March 19, 2018, 10:32
Francisco Palacios
fpalacios is on a distinguished road
Hi Eran,
Oops... this is a clear problem with the SU2 documentation we will fix this to make it more clear.
As you know, we are storing the AOA in the solution file to be able to restart the solver when are running at a constant Cl (so the AoA in your config file is not correct). If you don't want to use the info in the solution file or the mesh file you just need to use :
% Discard the data storage in the solution and geometry files
% e.g. AOA, dCL/dAoA, dCD/dCL, iter, etc.
% Note that AoA in the solution and geometry files is critical
% to aero design using AoA as a variable. (NO, YES)
DISCARD_INFILES= YES
Best,
Francisco
fpalacios is offline   Reply With Quote
Old   March 19, 2018, 16:48
Smile
Eran Arad
Thanks Fransico
It works well now
Eran
Old   March 19, 2018, 16:51
Eran Arad
Sorry, should have been Francisco
direct solution, restart problem
[PyFoam] running pyFoam(Plot)Runner.py in parallel Studi OpenFOAM Community Contributions 10 September 6, 2015 17:38
meshing of a compound volume in GMSH shawn3531 OpenFOAM 4 March 12, 2015 11:45
Problem with multiframe restart of two-way fsi coupled problem Dimone CFX 26 December 20, 2011 11:10
Force can not converge colopolo CFX 13 October 4, 2011 23:03
compile errors of boundary condition "expDirectionMixed" liying02ts OpenFOAM Bugs 2 February 1, 2010 21:11
