March 2, 2018, 05:06 |
SU2 v6.0 turbulence models.
Rep Power: 11 |
Hi all,
Was curious if anyone could point me in the direction of the references behind the latest turbulence models added in SU2 v6.0. (SA_NEG, SA_E, SA_COMP and SA_E_COMP) I'm curious what are the exact differences as I'd like to do a turbulence modelling study on buffeting. SIDE NOTE: Does anyone know how to make SU2 stop writing the *.csv solution every time step in unsteady simulations? I've had troubles using the WRT_CSV_SOL = NO command. Regards, |
March 2, 2018, 05:26 |
Rep Power: 11 |
searched the code and found out that:
SA_NEG = SA Negative Allmaras, S. R., Johnson, F. T., and Spalart, P. R., "Modifications and Clarifications for the Implementation of the Spalart-Allmaras Turbulence Model," ICCFD7-1902, 7th International Conference on Computational Fluid Dynamics, Big Island, Hawaii, 9-13 July 2012. SA_E = SA with Edwards Correction Edwards, J. R. and Chandra, S. "Comparison of Eddy Viscosity-Transport Turbulence Models for Three-Dimensional, Shock-Separated Flowfields," AIAA Journal, Vol. 34, No. 4, 1996, pp. 756-763. SA_COMP = SA with compressibility correction Spalart, P. R., "Trends in Turbulence Treatments," AIAA 2000-2306, June 2000. |
models, su2, theory, turbulence, turbulence modelling |
Adding turbulence models to (reacting)TwoPhaseEulerFoam | lavdwall | OpenFOAM Running, Solving & CFD | 0 | February 3, 2017 04:04 |
y+ range for turbulence models | babri | FLUENT | 1 | August 30, 2016 18:39 |
in k-epsilon wall function approach high Re turbulence models: question of velocity | romant | OpenFOAM Programming & Development | 6 | May 26, 2016 10:14 |
Advice about turbulence models? | mqsim | OpenFOAM Running, Solving & CFD | 6 | April 27, 2016 08:50 |
Only two turbulence options available in CFX Pre | Jack001 | CFX | 5 | March 30, 2016 03:47 |
