Home > Forums > Software User Forums > SU2
convergence issues with Roe Solver on transonic inviscid steady case
Old   February 9, 2018, 06:43
Default convergence issues with Roe Solver on transonic inviscid steady case
CarlosLozano is on a distinguished road
I'm running a simple transonic, inviscid, steady case on a NACA0012 with M = 0.8 and aoa = 1.25. I'm using the mesh provided in the suite (mesh_NACA0012_inv.su2) and Roe's scheme in both the flow and adjoint solvers and I'm having problems getting them to converge. Quite early on the residuals stall and oscillate, as do the corresponding metrics (Cl, Cd & Sens_Geo, Sens_aoa). It is probably a limiter-related issue (I'm using Venkat.). I copy the settings below. Any clues?
% -------------------------- MULTIGRID PARAMETERS -----------------------------%
% Multi-Grid Levels (0 = no multi-grid)
MGLEVEL= 3
% Multi-grid cycle (V_CYCLE, W_CYCLE, FULLMG_CYCLE)
MGCYCLE= W_CYCLE
% Multi-Grid PreSmoothing Level
MG_PRE_SMOOTH= ( 1, 2, 3, 3 )
% Multi-Grid PostSmoothing Level
MG_POST_SMOOTH= ( 0, 0, 0, 0 )
% Jacobi implicit smoothing of the correction
MG_CORRECTION_SMOOTH= ( 0, 0, 0, 0 )
% Damping factor for the residual restriction
MG_DAMP_RESTRICTION= 1.0
% Damping factor for the correction prolongation
MG_DAMP_PROLONGATION= 1.0
% -------------------- FLOW NUMERICAL METHOD DEFINITION -----------------------%
% Convective numerical method (JST, LAX-FRIEDRICH, CUSP, ROE, AUSM, HLLC,
% TURKEL_PREC, MSW)
CONV_NUM_METHOD_FLOW= ROE
% Spatial numerical order integration (1ST_ORDER, 2ND_ORDER, 2ND_ORDER_LIMITER)
SPATIAL_ORDER_FLOW= 2ND_ORDER_LIMITER
% Slope limiter (VENKATAKRISHNAN, MINMOD)
SLOPE_LIMITER_FLOW= VENKATAKRISHNAN
% Coefficient for the limiter (smooth regions)
LIMITER_COEFF= 0.1
% 1st, 2nd and 4th order artificial dissipation coefficients
AD_COEFF_FLOW= ( 0.15, 0.5, 0.02 )
% Time discretization (RUNGE-KUTTA_EXPLICIT, EULER_IMPLICIT, EULER_EXPLICIT)
TIME_DISCRE_FLOW= EULER_IMPLICIT
% ---------------- ADJOINT-FLOW NUMERICAL METHOD DEFINITION -------------------%
% Convective numerical method (JST, LAX-FRIEDRICH, ROE)
CONV_NUM_METHOD_ADJFLOW= ROE
SPATIAL_ORDER_ADJFLOW= 2ND_ORDER_LIMITER
% Slope limiter (VENKATAKRISHNAN, SHARP_EDGES)
SLOPE_LIMITER_ADJFLOW= VENKATAKRISHNAN
% 1st, 2nd, and 4th order artificial dissipation coefficients
AD_COEFF_ADJFLOW= ( 0.15, 0.5, 0.02 )
% Reduction factor of the CFL coefficient in the adjoint problem
CFL_REDUCTION_ADJFLOW= 0.5
% Time discretization (RUNGE-KUTTA_EXPLICIT, EULER_IMPLICIT)
TIME_DISCRE_ADJFLOW= EULER_IMPLICIT
CarlosLozano is offline   Reply With Quote
Old   February 10, 2018, 20:37
Mehdi Mortazawy
mhd_mrt is on a distinguished road
Originally Posted by CarlosLozano View Post
MGLEVEL= 3
MGCYCLE= W_CYCLE
% TURKEL_PREC, MSW)
LIMITER_COEFF= 0.1
Hi Carlos,
Try lowering the CFL number. Also th elimiter Coeff, try lowering that too. It could also be due to time descritization. I used to get numerical instability due to implicit time scheme. Try using Explicit and lowering the CFL number to see if you get any improvement.
Cheers,
mhd_mrt is offline   Reply With Quote
Old   February 11, 2018, 05:18
Originally Posted by mhd_mrt View Post
Hi Carlos,
Cheers,
Thanks for the advice
Old   February 24, 2018, 13:25
Francisco Palacios
fpalacios is on a distinguished road
If you eliminate the multigrid the you can really increase the CFL number.
Best,
Francisco
fpalacios is offline   Reply With Quote
Old   March 4, 2018, 06:23
Best,
Francisco
Thanks a lot for the advice
Regards
Adjoint Solver Convergence devesh.baghel STAR-CCM+ 7 October 9, 2018 08:05
Test Case CFL Number Issues with Software Update JBCFD SU2 3 July 14, 2017 13:05
Inviscid Solver Convergence (2D supersonic flow) gdbb89 FLUENT 2 March 10, 2016 09:03
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 15:53
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
