Home > Forums > Software User Forums > SU2
Fix constant timestep with explicit TIME_STEPPING simulations, is it possible?
Old   February 2, 2018, 04:05
Default Fix constant timestep with explicit TIME_STEPPING simulations, is it possible?
anonymous
ssss is on a distinguished road
I am trying to run explicit simulations in SU2 using UNSTEADY_SIMULATION= TIME_STEPPING and EULER_EXPLICIT time scheme. However, I am not able of setting a constant timestep. I know how to impose constant dt with dual time stepping simulations, but I cannot find a way to impose the same constant time step with the normal time stepping method. I have tried using MAX_DELTA_DT together with a high CFL number but this doesn't work.
I would mind using a constant CFL in my simulations, the problem is that there is no way of obtaining the physical time from the surface_flow*.csv and history.vtk files, any idea on how to obtain the physical time of the output files given by SU2?
Thank you
ssss is offline   Reply With Quote
Old   February 24, 2018, 13:36
Francisco Palacios
fpalacios is on a distinguished road
Have you try with
% Unsteady simulation (NO, TIME_STEPPING, DUAL_TIME_STEPPING-1ST_ORDER,
% DUAL_TIME_STEPPING-2ND_ORDER, HARMONIC_BALANCE)
and the options in UNSTEADY SIMULATION section?
Best,
Francisco
If that doesn't work... I think it would be a good idea to take a look at the source code. What you are proposing is a reasonable capability that should be in SU2.
Best,
Francisco
fpalacios is offline   Reply With Quote
Hyperelastic Material model in Explicit Dynamics sghod17 Structural Mechanics 0 July 17, 2015 17:07
fluid flow but temperature raises from nowhere? mxcfd STAR-CCM+ 5 September 16, 2014 06:46
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 19:44
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 07:25
Really big problems when creating own materials da Jop FLUENT 0 June 28, 2007 12:15
