Alexandre Payot
Rep Power: 0 ![]() |
Is it possible to define a 2D mesh in SU2 entirely using line elements? i.e. Can I ommit defining the volumes in a .su2 mesh format and only define the edges? This is because I need to run cutcell meshes which can include cells which are arbitrary polygons. I am testing this out on a triangular mesh for which I have two versions: - one where elements are triangles with the following format: 5 node1 node2 node3 triangle1 - one where elements are lines with the following format: 3 node1 node2 lines The nodes and boundaries are then the same. The mesh with the triangle elements runs fine but the one with the line elements crashes at the stage of "Read Grid File Information" with an OS error message but nor error failure message from the code. I'm including below the last lines of the output. ---------------------- Read Grid File Information ----------------------- Two dimensional problem. 7492 points. 2 surface markers. 407 boundary elements in index 0 (Marker = -1). 32 boundary elements in index 1 (Marker = -2). |
Francisco Palacios
Rep Power: 15 ![]() |
Nope... I don't think it is possible, but if are looking to reproduce a classical 1D simulation (like Sod's tube) it is easy to create a 2D grid that behaves like a 1D one (two points in the y direction).
Best, Francisco |
edge mesh, mesh 2d |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 04:18 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
GMSH - Very strange effect - Mesh elements deleted when saving | Araist | Mesh Generation & Pre-Processing | 3 | July 15, 2015 06:03 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
OpenFOAM15 installables are incomplete problem with paraFoam | tryingof | OpenFOAM Bugs | 17 | December 7, 2008 04:41 |
