November 28, 2017, 19:26 |
Animating the Laminar Cylinder Tutorial
Adam Freund
Rep Power: 9 |
Hi all,
I've run into a snag in my attempts to learn SU2. I have no difficulty running the tutorials provided but I noticed the laminar cylinder tutorial does not produce enough recorded iterations to make an animation. How might I tweak the settings of the .cfg file so that I can create an animation? Also, if someone could direct me to material that will increase my understanding of CFD/DFT simulation I would be very grateful. Thanks in advance! Adam |
December 19, 2017, 05:08 |
Hi Adam,
Are you running the simulation steady state? If you run the simulation unsteady then usually SU2 will output files after a set number of user defined iterations which can be used to create an animation. |
animation, laminar cylinder, su2 |
Lift Cylinder in Liquid using ANSYS | MikeShuo | Main CFD Forum | 0 | October 24, 2016 01:46 |
Cylinder vortex shedding (3D) | Apocolapse | STAR-CCM+ | 2 | April 3, 2014 20:33 |
flow over a cylinder, turbulent and laminar | Chetan Kadakia | FLUENT | 27 | December 8, 2012 05:08 |
Transient Laminar Flow over a circular cylinder | bababanamzdaalma | Main CFD Forum | 2 | March 1, 2012 12:37 |
rotating cylinder using sliding mesh | Tim Daly | FLUENT | 1 | November 9, 2008 23:02 |
