Home > Forums > Software User Forums > SU2
Divergance problem SU2
Old   November 23, 2017, 07:42
Default Divergance problem SU2
MM
McAero is on a distinguished road
Hello All,
I hope someone can help me,
I am Student and still learning CFD , i wanna make computations for NACA0012 2D i tried many configurations but it`s not converging , always diverging
the physical case is :
Navier stokes equations Incompressible
AoA : zero
Re No. : 649328
Velocity : 45 m/sec in The X direction only
my mesh is a c shape with inlet named 'OPEN' as the c
and the sym is 'FLUID'
and the outlet is 'OUT'
and the foil named 'WALL'
I hope i cant` find some , i`d really appreciate it ))
Kindly find attached the cfg file and cgns
Thanks a lot
McAero is offline   Reply With Quote
Old   November 23, 2017, 07:52
Default configuration file
MM
Here is the configuration file , i couldn`t upload the cgns
Old   December 1, 2017, 14:19
Akshay Koodly
akoodlyr is on a distinguished road
Have you tried using the config file settings from https://github.com/su2code/SU2/tree/..._rans/naca0012 ?
akoodlyr is offline   Reply With Quote
Old   December 1, 2017, 14:51
MM
Thanks very much for your reply
Yes i tried but still diverging
Old   December 1, 2017, 15:23
Akshay Koodly
Have you used the mesh files from
https://github.com/su2code/TestCases..._rans/naca0012 ?
Also, can you get rid of the outlet and inlet boundary conditions and instead set OPEN and OUT as FARFIELD?
Old   December 1, 2017, 16:51
MM
Thanks very much for your support
i have replaced the Far-field with ( OPEN, OUT ) but it`s still diverging very fast
Thanks again for your support
Old   December 2, 2017, 05:54
Akshay Koodly
Ok, can you try to use the mesh and BCs from this https://turbmodels.larc.nasa.gov/naca0012_val.html ?
It is a validation case on NACA 0012 but the trailing edge is modified to be sharp. They have a bunch of (unstructured) CGNS mesh files there (https://turbmodels.larc.nasa.gov/naca0012_grids.html). You can download them. Use the cfg file from the link I gave previously and change the mesh name and markers. Can you run the case and see if it still diverges?
Old   December 2, 2017, 20:36
MM
Thanks a lot and sorry for the late reply
But unfortunately it`s all 3D cgns files
i and i don`t know th names for the markers
3D Windturbine simulation in SU2 k.vimalakanthan SU2 15 October 12, 2023 06:53
SU2 process was terminated by signal '11' tomp1993 SU2 Shape Design 5 March 1, 2018 05:32
divergance detected in amg solver-coupled hamed1987 FLUENT 10 February 24, 2016 15:24
Official Release of SU2 V3.2 economon SU2 News & Announcements 6 April 18, 2015 00:28
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
