November 13, 2017, 15:44 |
Questions from a Newbie
Adam Freund
Rep Power: 9 |
Hi all,
I am not new to CFD but I am an absolute novice when it comes to SU2. I hope my questions are not repeats but I haven't found anything pertaining to them on the forum so I suppose it's ok. I am trying to run the "laminar flow over a cylinder" test case from the SU2 wiki but I cannot seem to find the lam_cylinder.cfg they refer to in the instructions. Am I supposed to create it from the config_template.cfg and, if so, do I need to introduce null values for the unneeded options? Thanks again and apologies if this is a repeat question.Adam |
November 14, 2017, 05:41 |
Tim Albring
Rep Power: 11 |
Hi Adam,
you should find all the config files in the TestCases folder inside the main SU2 directory. In particular the config file for the case you mentioned is in TestCases/navierstokes/cylinder. Please note that the mesh files are in a separate repository (https://github.com/su2code/TestCases). More information can be found here: https://github.com/su2code/SU2/wiki/Test-Cases Tim
Developer Director @ SU2 Foundation Get involved:
November 14, 2017, 18:09 |
#3 | |
Adam Freund
Rep Power: 9 |
Thanks for your help it seems I unpacked the tar file and did not correctly configure. If you don't mind I'd like to pick your brain a bit more. I am trying to visualize the "laminar flow over a cylinder" tutorial using Paraview but I am unable to display the streamlines correctly. Is this due to my ignorance of Paraview or does it have something to do with the .vtk I made as my output. Also, do you know if it is possible to create an output file that is compatible with the post processing program Visit? When I tried to visualize in Visit I could only get errors. Thanks again! Adam |
[GAMBIT] Few newbie questions | ajkratos | ANSYS Meshing & Geometry | 5 | February 28, 2011 22:26 |
total newbie - Basic Questions | caslor | Main CFD Forum | 9 | December 10, 2009 11:49 |
Newbie Navier Stokes Questions + Grid | Jigar | Main CFD Forum | 4 | February 6, 2006 12:14 |
newbie: simple questions about pressure poisson eq | cfd-newbie | Main CFD Forum | 19 | February 4, 2006 06:48 |
Newbie questions | Anders Olofsson | Main CFD Forum | 7 | September 1, 2000 16:19 |
