November 8, 2017, 20:36 |
Parallel Build for SU2 on Ubuntu
MM
Rep Power: 9 |
Hello All,
Excuse me, I am quite new to ubuntu and su2 I have installed SU2 4.0.0 " Cardinal " it`s supposed to be a parallel release but when I run a test case only single core is running, how can I use su2 for parallel computations I read about some python scripts but I don`t understand how to make these processes. I'd be very glad for your help thanks very much for your help |
November 9, 2017, 03:09 |
Amir A. Abdelqodus
Rep Power: 9 |
Hi
Firstly,it's better to install the latest version of SU2. You can find the installation instructions on their website. Get it using git client. secondly, did you compile it with mpi support? and added the environmental variables to the bash file? if so you can run it in parallel using: mpirun -n j SU2_CFD ./file-name.cfg [j is the number of cores] Then SU2_SOL ./file-name.cfg after the simulation is solved, to generate the post processing files. Or better use " parallel_computation.py -n j -f file-name.cfg " which is a python script to automate this whole process. |
November 9, 2017, 03:33 |
Amir A. Abdelqodus
Rep Power: 9 |
You will need to install [python, mpi4py, numpy, scipy] in order for the python scripts to work.
https://github.com/su2code/SU2/wiki/Installation you can use: sudo apt-get install swig sudo apt-get install python-pip sudo pip install mpi4py numpy scipy |
November 9, 2017, 07:50 |
MM
Rep Power: 9 |
Thanks very Much Amiradib for your reply it was very helpful
I am very grateful i hope you can help me in another small inquiry related to the BC naming in the cfg file I have a problem with running SU2 for a CGNS file , I have 2D mesh extruded - made by ICEM I have Boundraies : WALL OPEN OUT FLUID FLUID_2 when I run the code it give me this error "The configuration file doesn't have any definition for marker FLUID_2D!!" but when I use the 2D mesh only without two sym boundaries it worked ok Loading CGNS data into SU2 data structures. Three dimensional problem. 94548 interior elements. 127440 grid points. 5 surface markers. 717 boundary elements in index 0 (Marker = OPEN). 831 boundary elements in index 1 (Marker = OUT). 31516 boundary elements in index 2 (Marker = FLUID_2D). The configuration file doesn't have any definition for marker FLUID_2D!! I`d really appreciate your help Thanks a lot ) |
November 9, 2017, 11:13 |
Amir A. Abdelqodus
Rep Power: 9 |
You are welcome, I am glad I was able to help!
I am not sure if I understand your problem correctly, but as I understand you have 2 symmetry planes (FLUID & FLUID_2). If this is the case, try this in the BCs in the config file: MARKER_SYM= ( FLUID, FLUID_2 ) and check these tutorials, maybe they will help: https://github.com/su2code/SU2/wiki/Inviscid-ONERA-M6 or https://github.com/su2code/SU2/wiki/Turbulent-ONERA-M6 If this doesn't work, paste your cfg. Maybe me or others can help. Good luck! |
November 9, 2017, 14:03 |
MM
Rep Power: 9 |
Thanks very much for your reply
the problem is in something called FLUID_2D in the CGNS file, I don`t have any part named FLUID_2D when I made it on ICEM and even the cfg file doesn`t have this word . What do you recommend? |
November 14, 2017, 14:28 |
Amir A. Abdelqodus
Rep Power: 9 |
Hi!
I don't know the reason of this problem. Maybe try to generate the mesh from the beginning, and be careful with the part names. Hope this helps |
November 15, 2017, 07:56 |
MM
Rep Power: 9 |
Thanks a lot
About the building up of parallel setup, i discovered that i after adding the scipy numpy and mpi that the iterations are just repeated 4 times ! how to compile the code for parallel computations, as you said adding some variables to the bash file. Excuse me, I am a very beginner user of Linux and tried to understand from github page of SU2 but couldn`t make it can you give me the command lines for the compiling and how to use it Thanks very much for your support |
November 21, 2017, 13:30 |
#9 |
Akshay Koodly
Rep Power: 9 |
The instructions to install SU2 in parallel are specified here (https://github.com/su2code/SU2/wiki/Parallel-Build). You have to use the enable mpi flag and specify the path to the location where mpicxx and mpicc (the parallel C++ and C compilers) are installed in your system. The difference between building SU2 in parallel and serial is in the configure command - To build in serial you have probably used ./configure --prefix=/path/to/install/SU2 For parallel you have to add extra flags to the configure command.The new command will be ./configure --prefix=/path/to/install/SU2 --enable-mpi --with-cc=/path/to/mpicc --with-cxx=/path/to/mpicxx path/to/mpicc and /path/to/mpicxx must point to the local directories where mpicc and mpicxx are located in your machine. After this you just do make install as before. Re error when running SU2, it looks like there is some typo when specifying the boundary conditions. From the output you have posted, there is a marker named FLUID_2D in the mesh file but the cfg file contains definition for FLUID_2 and not FLUID_2D. Make sure the marker definitions in the cfg file and mesh file are same. Cheers. |
October 26, 2018, 20:07 |
#10 | |
Peter Shi
Rep Power: 9 |
Do you know what is the difference using mpi and python scripts to run SU2 in parallel? Will the simulation time differ using two methods? Thank you. Best, Peter |
October 28, 2018, 13:30 |
#11 |
Amir A. Abdelqodus
Rep Power: 9 |
Hi Peter,
There is virtually no difference between using these two methods to run SU2, since the rule of the python scripts is to automate executing both the analysis and post processing. So, there is no difference in simulation time, but it is just more convenient to use the python script. Hope this helps. |
October 28, 2018, 18:53 |
#12 | |
Peter Shi
Rep Power: 9 |
Thank you for your reply. But yesterday, I tested one case (500,000 cells) by running SU2 in serial and parallel with MPI, and parallel simulation was even slower than the serial case, which made me think MPI is probably not the right way to run SU2 in parallel. Python parallel simulation does not work in my machine for now, I expect it will be faster than MPI. Best regards, Peter |
Error running simpleFoam in parallel | Yuby | OpenFOAM Running, Solving & CFD | 14 | October 7, 2021 05:38 |
chtMultiRegionSimpleFoam: crash on parallel run | student666 | OpenFOAM Running, Solving & CFD | 3 | April 20, 2017 12:05 |
Some questions about a multi region case run in parallel | zfaraday | OpenFOAM Running, Solving & CFD | 5 | February 23, 2017 11:25 |
[OpenFOAM.com] Error build a custom version of Qt 4.6.4 on ubuntu 12.04 | makayasa | OpenFOAM Installation | 5 | April 2, 2016 19:22 |
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 | Amitava Majumdar | Main CFD Forum | 0 | January 5, 1999 13:00 |
