November 7, 2017, 23:22 |
How to change su2 format to cgns format?
Bingfei
Rep Power: 10 |
Hi all,
When I'm trying to optimize ONERA M6 wing using the mesh file with FFD information made by myself, it always diverged in the second step So I decided to check the mesh file (mesh_ONERAM6_inv_FFD_02_deform.su2)generated in the second step, but it can't be opened in Tecplot Therefore I want to change the su2 format to cgns or other format that can be check in Tecplot. But I don't know how to do it :/ Does anyone meet the same problem or know how to solve it? Any advice will be grateful! Bingfei |
November 8, 2017, 03:28 |
Tim Albring
Rep Power: 11 |
Hi Bingfei,
you can do that with SU2_DEF. Add the following options to your config file: DV_KIND= SCALE DV_MARKER = comma separated list with ALL your markers DV_PARAM = (0,0) DV_VALUE = 1.0 VISUALIZE_DEFORMATION= YES Then run SU2_DEF. You should find a file volumetric_deformation.dat in the folder which you can open with Tecplot. Tim PS: Just saw that you are running an optimization. Then it is even easier: Just add the option VISUALIZE_DEFORMATION= YES to your config file and run the optimization again. Then you should the above mentioned file in the folder DESIGNS/DSN_002/DEFORM.
Developer Director @ SU2 Foundation Get involved:
Last edited by talbring; November 8, 2017 at 03:32. Reason: added an easier option |
November 8, 2017, 09:35 |
Bingfei
Rep Power: 10 |
Thanks Tim!
That really helps! |
how to export cfx result to CGNS format | littlelz | CFX | 3 | April 29, 2010 08:15 |
use of cylindrical coordinates CGNS format | Vinayender | Main CFD Forum | 1 | May 13, 2008 09:20 |
Multizone unstructerd mesh frm icem in cgns format | Michael | CFX | 0 | October 13, 2006 03:30 |
Gambit and CGNS format | Jenna | FLUENT | 0 | March 27, 2005 09:54 |
cgns format | dimitris | Main CFD Forum | 1 | January 29, 2001 01:22 |
