Tim Jim
Rep Power: 8 ![]() |
I'm still fairly new to SU2, so apologies if this is an obvious question. I was wondering how the suffix of history file is set? I had a look through the SU2 pages and found the following on https://github.com/su2code/SU2/wiki/Post-processing: history.dat or history.csv: file containing the convergence history information. However, I notice that I also get a history.vtk in some runs. I'm aware that the convergence log name is set by the .cfg file but what determines the suffix (.dat, .csv, .vtk)? Is it set by the output format? I hope I'm posting in the right sub-forum! |
Tim Albring
Rep Power: 10 ![]() |
Hi tijm,
the extension is determined by the option OUTPUT_FORMAT. If it is TECPLOT you get a *.dat file and for PARAVIEW a *.csv file. Tim
Developer Director @ SU2 Foundation Get involved:
Tim Jim
Hi, Tim,
Thanks for the message. when the output is set to PARAVIEW, I get the 'vtk' extension (history.vtk) but it is indeed a file of comma separated values. Will the format stay consistent for this version? Many thanks, Tim |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 | towanda | OpenFOAM Community Contributions | 6 | September 5, 2015 21:03 |
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error | FerdiFuchs | OpenFOAM Community Contributions | 27 | April 16, 2014 15:14 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
