Home > Forums > Software User Forums > SU2
2 Questions: Fully implicit compressible Solver and time depentend pressure inlet?
Old   September 22, 2017, 08:11
Default 2 Questions: Fully implicit compressible Solver and time depentend pressure inlet?
hxaxtma is on a distinguished road
Hi guys,
2 Qiestions:
1) does SU2 has an fully implicit compressible solver for high mach number cases
2) Is it possible to define a time-dependent pressure bc for the inlet
For example for calculating supersonic nozzle flow (transient, not steady!)
hxaxtma is offline   Reply With Quote
Old   September 25, 2017, 09:23
Tim Albring
talbring is on a distinguished road
to answer your questions:
1) Yes, SU2 uses a fully-implicit formulation (when you set TIME_DISCRE_FLOW to EULER_IMPLICIT)
2) Unfortunately that is not possible yet. But you can easily implement that yourself. The corresponding routine can be found in SU2_CFD/src/solver_direct_mean.cpp and is called CEulerSolver::BC_Inlet().
Regards,
Tim
talbring is offline   Reply With Quote
Old   September 25, 2017, 09:26
Thanks for the information
courant number increases to rather large values 6863523 OpenFOAM Running, Solving & CFD 22 July 6, 2023 00:48
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 01:01
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
