Home > Forums > Software User Forums > SU2
Test cases for incompressible rotating flow.
Old   August 25, 2017, 20:35
Default Test cases for incompressible rotating flow.
Akshay Koodly
akoodlyr is on a distinguished road
Could anyone suggest some test cases(possibly 2-D) for incompressible rotating flows?
I have a couple of 3-D cases and they take too long to compute and I would like to use a simpler case with which I can test the solver as I make changes to the code.
Cheers.
akoodlyr is offline   Reply With Quote
Old   September 2, 2017, 22:37
Francisco Palacios
fpalacios is on a distinguished road
What kind of application do you have in mind?
for 2D... maybe the turbomachinery folder is a good option. Otherwise, maybe you can just take an airfoil grid and apply some rotation to simulate a horizontal wind turbine. like in https://www.youtube.com/watch?v=EM4jeOW_2CI
Maybe you can take a look at the example in the harmonic_balance folder
Best,
Francisco
fpalacios is offline   Reply With Quote
Old   September 29, 2017, 12:41
Akshay Koodly
I am interested in wind turbine simulations and wanted to see if I can run the code for some simple cases first. I ran the turbomachinery cases and tried to use the same free stream definitions for an incompressible flow, but wasn't able to get the same results. For now, I ran a Couette flow case which has an analytical solution but needs rotating wall not rotating reference frame. I will also look at some cases in harmonic balance folder. Thank you for the suggestion.
Also, I realize MACH_MOTION is used to non-dimensionalize the rotational velocities, compute forces and other post processing steps(Momentum_forces, Pressure_Forces..) but the gas constant appears to be undefined for incompressible flows(not there in SetNondimensionalization and couldn't find any default value). This makes Omega_ref undefined which blows up the solution immediately. As a temporary fix, I added a new config option Radius_of_Rotation and used the input omega to initialize Omega_ref. It appears to work for some simple cases I ran but I am yet to test if it affects any other part of the code.
Cheers.
incompressible flow, rotating frame
Fluent: Flow won't interact with rotating region TOlsen FLUENT 0 September 26, 2016 12:30
Rotating flow nasir.iitd FLUENT 6 June 2, 2014 13:41
Gate valve flow simulations... nikesh FloEFD, FloWorks & FloTHERM 5 January 28, 2014 02:31
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
FSI test cases Kirikou Main CFD Forum 8 November 6, 2006 10:49
