July 27, 2017, 12:05 |
LAPACK with SU2
Rep Power: 10 |
Hi there,
I have looked at an earlier post regarding how to enable LAPACK in SU2 and am following the steps. (Link: Using LAPACK in SU2). Firstly, I compiled blas, lapack and lapacke, and was able to call the functions in LAPACKE/lapacke.h. I then ran configure with the following options: --enable-mpi --with-cc=/path/to/mpicc --with-cxx=/path/to/mpicxxThe following message was printed after running configure, confirming that I have the required include file and library: checking for /path/to/lapack/liblapacke.a... yesI then added a line "#include <lapacke.h>" in one of the header files in "SU2/Common/include" just to test if LAPACK is indeed enabled on SU2. When running make, the following error appears: fatal error: lapacke.h: No such file or directoryEven if I use the full path in the header file, i.e. "#include "/path/to/lapack/LAPACKE/include/lapacke.h", the compiler is unable to find the function when I called LAPACK_dgetrf in the .cpp file. Seems like the include and library paths are not set up correctly in the Makefile. I am not sure what is missing here and what else do I need to do to get access to the LAPACK subroutines. Any help would be greatly appreciated. I am using SU2 version 5.0.0 on my Thinkpad with Ubuntu 16.04.2 installed. Also, the LAPACK version is 3.7.1. Thanks Joel |
July 31, 2017, 14:20 |
Rep Power: 10 |
I found a way around it in case anyone runs into the same problem. I'm still a beginner with C++ so it may seem trivial. Anyways...
Running ./configure with the following options on top of those needed for MPI etc. worked for me (with gnu compiler): CPPFLAGS="-DHAVE_LAPACK -I/path/to/lapack/LAPACKE/include" |
compilation error, lapack, linking, su2 |
How to compile SU2 with LAPACK in MKL | chengdi | SU2 Installation | 2 | October 23, 2015 11:51 |
Using LAPACK in SU2 | shainath | SU2 | 2 | November 28, 2014 01:34 |
Pointwise-SU2 joint webinar (April 29th) and SU2 v3.1.0 new release | fpalacios | SU2 News & Announcements | 1 | April 30, 2014 03:40 |
Official release of SU2 V3.0 and SU2 Educational V1.0 | fpalacios | SU2 News & Announcements | 2 | January 22, 2014 06:28 |
Welcome to the Stanford University Unstructured (SU2) forum! | economon | SU2 | 0 | January 7, 2013 03:48 |
