Home > Forums > Software User Forums > SU2
set_ffd_design_var.py
Old   July 20, 2017, 16:04
Default set_ffd_design_var.py
Ryan. is on a distinguished road
I want to generate design variables using set_ffd_design_var.py. The problem is when I run it, it always shows the same variables for DV_DEFINITION on the screen:
DEFINITION_DV= ( 7, 1.0 | None | 0, 0, 0, 0, 0.0, 0.0, 0.0 ); ......
Could you please tell me what I'm doing wrong?
Thanks.
Ryan. is offline   Reply With Quote
Old   August 11, 2017, 11:19
Francisco Palacios
fpalacios is on a distinguished road
Hi Ryan,
Thanks for using SU2!
Could you please try with set_ffd_design_var.py -h . Doing so you will see all the options that you need to add to run the script.
Thanks!
Francisco
fpalacios is offline   Reply With Quote
Old   August 11, 2017, 14:05
Originally Posted by fpalacios View Post
Hi Ryan,
Thanks!
Francisco
Thank you very much for clearing that up
adjoint, ffd, ffd 2d optimization su2, su2
