Floris
Rep Power: 9 ![]() |
Hello guys!
In order to test whether SU2 is installed correctly, I ran the test case RAE-2822 and this gave some strange behavior... However the first optimization try gives the good results: NIT FC OBJFUN GNORM 1 1 1.345e-5 3e-3 2 2 1.1214e-5 1e-3 3 3 1.113e-5 7e-4 However when I copied the folder and run it again, it will give the following result: NIT FC OBJFUN GNORM 1 1 1.345e-5 1.14e-3 2 4 1.1209e-5 3.7e-3 3 8 1.116e-5 3.22e-3 Furthermore I saw that the DV_values in the first try are changing randomly. However the third/fourth/etc. run are just divided by 2 each time... I hope somebody can indicate the source of this problem and might have a suggestion to overcome this problem Thanks in advance! Kind regards, Floris |
dv_value, testcase |
OpenFOAM - Validation of Results | Ahmed | OpenFOAM Running, Solving & CFD | 10 | May 13, 2018 18:28 |
lid driven cavity varying results | yasmil | OpenFOAM Running, Solving & CFD | 2 | October 6, 2016 21:42 |
interFoam simulation yields inconsistent results for alpha1 surface | Ralinus | OpenFOAM Running, Solving & CFD | 8 | January 13, 2014 08:54 |
CFD results not close to experimental results | cider | STAR-CCM+ | 0 | July 8, 2013 07:53 |
Different Results from Fluent 5.5 and Fluent 6.0 | Rajeev Kumar Singh | FLUENT | 6 | December 19, 2010 11:33 |
