Home > Forums > Software User Forums > SU2
Questions on Vertex Normal for 2D Cases
Old   June 17, 2017, 20:13
Default Questions on Vertex Normal for 2D Cases
Joel Ho is on a distinguished road
Hi there,
I am wondering why in the function CPhysicalGeometry::SetBoundControlVolume, the vertex normal for 2D is calculated with:
vertex[iMarker][iVertex]->SetNodes_Coord(Coord_Elem_CG, Coord_Vertex);
I could be misunderstanding the code but my impression is that it should be:
vertex[iMarker][iVertex]->SetNodes_Coord(Coord_Edge_CG, Coord_Vertex);
Could there be something that I am missing there? Any help is greatly appreciated. The above code was found in: SU2/Common/src/geometry_structure.cpp.
Thanks
Joel
Joel Ho is offline   Reply With Quote
boundary cells, dual mesh, normal to edge, su2
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 06:29
How to get normal vector to the face? Viatcheslav Kulikov FLUENT 1 August 31, 2017 04:03
UDF to Access Wall Normal Concentration Gradient Daniel Tanner Fluent UDF and Scheme Programming 4 February 18, 2015 15:35
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 16:57
[surface handling] SurfaceMeshTriangulate lam OpenFOAM Meshing & Mesh Conversion 0 April 27, 2007 12:41
