Why is conservative_1 in incompressible flow the same as pressure?! |
June 7, 2017, 20:07 |
Rep Power: 9 |
I know the conservative_1 is supposed to be the density of the flow. However, in my 3d incompressible simulation with SST model, my conservative_1 field is the same as pressure (also includes negative values). I am a little confused about this since pressure is not a conservative field. Can someone please explain what is going on? Thanks |
June 8, 2017, 09:44 |
Ole Burghardt
Rep Power: 10 |
solving the incompressible equations is a bit different: "Find the fields that fulfill the conservation of mass/momentum/energy" already sounds more natural than "Find the fields that fullfill the conservation of momentum under the assumption that the velocity is divergence free". The "under the assumption" part is both in physical intuition and theory translated into finding a pressure field that effectuates this, in SU2 a method called "artificial compressibility" is used. So you are right, there is no "pressure conservation", but SU2 has to solve for the pressure and it's also not so odd to just put it in the Conservative_1's place as you might think: For compressible flows at low Mach numbers, you can simply translate pressure into density (or the other way around). So it's "nearly" such a mass conservation field if you think of it from the physical meaning's side. Hope that makes sense to you Regards, Ole |
June 8, 2017, 10:55 |
#3 | |
Rep Power: 9 |
conservative variables, conservative1, incompatible, sst k-omega, su2 |
Review: Reversed flow | CRT | FLUENT | 1 | May 7, 2018 05:36 |
Total pressure and mass flow boundary condition at inlet | bscphil | OpenFOAM Pre-Processing | 3 | July 9, 2017 14:39 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Is this a plausible incompressible pressure driven flow case? | yeya | OpenFOAM Running, Solving & CFD | 16 | September 19, 2016 03:45 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
