Home > Forums > Software User Forums > SU2
parallel get wrong results for parallel_computation.py inv_ONERAM6.cfg
Old   May 21, 2017, 00:58
Default parallel get wrong results for parallel_computation.py inv_ONERAM6.cfg
nuaa_bird is on a distinguished road
hello guys,
Im new for SU2. When learning the tutorial 3 for Inviscid ONERA M6 in the website, I faced problems. here is my question:
I get SU2 from SU2-4.1.100-Windows-x64-Single-Threaded.exe
using python 2.7
MPICH2
os: windows 8.1
In Serial: entering "SU2_CFD inv_ONERAM6.cfg" at the command line
and entering "parallel_computation.py -f inv_ONERAM6.cfg -n 1" at the command line
I get the right results as the toturial;
In paralell: entering "parallel_computation.py -f inv_ONERAM6.cfg -n 6" at the command line, it prints 6 times every iter
I get right CL,CD and some other coefficients, while the wrong Surface_flow.dat(wrong mesh even).
It seems that it didnt compute in 6 cores or cut the wing into 6 parts, but compute it 6 times.
what is paralell tools, how to check them work well, how I get SU2_DDC(if it work for my question)?
someone help me please;thanks a lot.
nuaa_bird is offline   Reply With Quote
Old   May 22, 2017, 07:19
WANG,Hao
Haowang is on a distinguished road
Originally Posted by nuaa_bird View Post
hello guys,
using python 2.7
MPICH2
os: windows 8.1
It's obvious that you didn't set the prallel environment properly. Please refer to this thread: Parallel execution of SU2
and:https://github.com/su2code/SU2/wiki/...ne-for-example
good luck!
Haowang is offline   Reply With Quote
Old   May 23, 2017, 01:35
thanks for your reply!
I re-compiled my su2_cfd with mpi and parmetis support, but here came new question,I ran with the command line in parallel, and it printed:
job aborted:
[ranks] message
[0] terminated
[1] process exited without calling finalize
-----error analysis--------
[1] on admin
D:\SU2\SU2_CFD ended prematurely and may have crashed. exit code 0xc0000005
--------error analysis-------
SU2 process was terminated by signal '3'
(ps: see my attachment for more info)
I checked source code, and found words, same with the error tips came out, "poor initial vertex distrabution. processor .. has no vertices as signed to it!" But I dont know why this. Maybe may parmetis has not cut the mesh? How to check parmetis work well?
any advice will be appreciated!
thanks!
Last edited by nuaa_bird; May 30, 2017 at 23:45. Reason: more details about my question.
Old   June 15, 2017, 09:55
job aborted:
[ranks] message
[0] terminated
[1] on admin
thanks!
The problem has beening solved...
It appears that my metis was compiled in a wrong way(there ara something wrong with the sln get from cmake(VS2010 compiler) do not work), so I recompiled metis from source using VS 2010. Fortunately, the parallel_compute.py work well after that!
hope this can help someone else!
inv_oneram6, paralle tools, parallel calculation, su2
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 19:45
Parallel processing results using FLUENT haihek FLUENT 3 August 5, 2012 08:55
interFoam 2.1.x gives wrong results on low Froude numbers lt.quibbler OpenFOAM Running, Solving & CFD 12 June 14, 2012 09:06
why dynamic mesh method give wrong results? weiyang1980 Main CFD Forum 0 September 22, 2009 22:06
view the results from parallel v3.2 matej Siemens 3 July 30, 2004 03:13
