Home > Forums > Software User Forums > SU2
Sensitivity information for custom design variables
Old   March 20, 2017, 07:39
Default Sensitivity information for custom design variables
DG
dghate is on a distinguished road
Dear All,
I trying out NACA0012 transonic airfoil optimisation problem. Default design variables are Hicks-Henne. I would like to use PARSEC parameterisation.
To get the gradient using the adjoint solver, SU2_DOT or SU2_DEF will have to provided the information regarding these custom design variables. I understand that a design variable change is translated into airfoil surface change which is then passed on to SU2_DEF which creates mesh perturbation in the volume grid. This mesh perturbation is the volume grid is used by SU2_DOT along with the direct and adjoint solutions to obtained the gradient with respect to that design variable.
In the SU2_DOT.cpp, I see that there is provision for custom design variables. However, I have not found any documentation or example that uses custom design variables.
Could someone please direct me to any available example/documentation ?
If not, I will have to understand how Hicks-Henne design parameters are implemented and then follow the procedure.
dghate is offline   Reply With Quote
su2 adjoint, su2 gradients
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
PHI file structure Eugene Phoenics 9 November 2, 2001 23:00
Design Integration with CFD? John C. Chien Main CFD Forum 19 May 17, 2001 16:56
CFD in a nutshell CFD Dummy Main CFD Forum 34 July 8, 2000 01:29
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 11:18
