Euler unsteady with moving boundary conditions - problem setup |
January 24, 2017, 10:11 |
Rocco
Rep Power: 9 |
Hello everybody,
This is my very first post on the forum as I'm just approaching all the possibilities offered by SU2, so I'm thanking in advance whoever is going to help me with my issue. What I want to achieve is an unsteady euler simulation with completely generic moving boundary conditions. Let's say I want to study a 2D airfoil with flap movement while, at the same time, plunging and pitching. My question is: how do I prescribe the Boundary deformations and motion? And how to prescribe the mesh deformation to follow the boundary movement? I want to underline that my following target is to study the fluid interaction with moving 3D boundaries (not rigid motion). Up to now, I found pretty good suggestions in the discussion: Mesh Generating Using Spring Analogy which however is incomplete and not clear. It is said I should use the command SU2_DEF and operate on the "-GRID DEFORMATION PARAMETERS-" section of the .cfg, prescribing DV_KIND= SURFACE_FILE and MOTION_FILENAME= mesh_motion.dat where the layout of the mesh_motion remains obscure to me (a set of motion for each time-step? how defined?). Tutorials for prescribed plunging and pitching of a 2D airfoils suggest to modify the "-DYNAMIC MESH DEFINITION-" section of the .cfg file. Defining the option GRID_MOVEMENT_KIND= EXTERNAL should resolve my problem? Other useful but incomplete suggestions were found in this discussion: Problem with dynamic mesh (EXTERNAL - 3D) My ideal prescribed motion would be given by redefining the points of the moving boundary time-step by time-step. Is this possibility implemented in the code? Thank you |
deforming mesh, euler, moving boundary, unsteady |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 08:30 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 12:19 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 18:30 |
Implementation of boundary conditions for FVM | Tom | Main CFD Forum | 7 | August 26, 2014 06:58 |
Boundary conditions? | Tom | Main CFD Forum | 0 | November 5, 2002 02:54 |
