Problem with running tutorial "Constrained Optimal Shape Design of a Fixed Wing" |
December 15, 2016, 03:16 |
JAMES
Rep Power: 9 |
Hi:
I'm now studying SU2 and try to run sample described in the tutorial "Constrained Optimal Shape Design of a Fixed Wing". When i run the "shape_optimization.py -f inv_ONERAM6_adv.cfg -n 8" in the terminal, after a few times, it shows "SU2 process returned error '1'", and the traceback is as follows: ------------------------------------------------------------------------------------------------------ File "/home/yg/su2/bin/shape_optimization.py", line 157, in <module> main() File "/home/yg/su2/bin/shape_optimization.py", line 101, in main options.quiet ) File "/home/yg/su2/bin/shape_optimization.py", line 140, in shape_optimization SU2.opt.SLSQP(project,x0,xb,its,accu) File "/home/yg/su2/bin/SU2/opt/scipy_tools.py", line 138, in scipy_slsqp epsilon = eps ) File "/usr/lib/python2.7/dist-packages/scipy/optimize/slsqp.py", line 206, in fmin_slsqp constraints=cons, **opts) File "/usr/lib/python2.7/dist-packages/scipy/optimize/slsqp.py", line 394, in _minimize_slsqp for con in cons['ineq']]) File "/home/yg/su2/bin/SU2/opt/scipy_tools.py", line 245, in con_dcieq dcons = project.con_dcieq(x) File "/home/yg/su2/bin/SU2/opt/project.py", line 240, in con_dcieq return self._eval(konfig, func,dvs) File "/home/yg/su2/bin/SU2/opt/project.py", line 184, in _eval vals = design._eval(func,*args) File "/home/yg/su2/bin/SU2/eval/design.py", line 144, in _eval vals = eval_func(*inputs) File "/home/yg/su2/bin/SU2/eval/design.py", line 509, in con_dcieq grad = su2grad(this_con,grad_method,config,state) File "/home/yg/su2/bin/SU2/eval/gradients.py", line 123, in gradient grads = geometry( func_name, config, state ) File "/home/yg/su2/bin/SU2/eval/gradients.py", line 709, in geometry info = su2run.geometry(config) File "/home/yg/su2/bin/SU2/run/geometry.py", line 95, in geometry SU2_GEO(konfig) File "/home/yg/su2/bin/SU2/run/interface.py", line 213, in GEO run_command( the_Command ) File "/home/yg/su2/bin/SU2/run/interface.py", line 297, in run_command raise exception , message SU2.EvaluationFailure: Path = /home/yg/su2/bin/DESIGNS/DSN_001/GEOMETRY/, Command = mpirun -n 8 /home/yg/su2/bin/SU2_GEO config_GEO.cfg SU2 process returned error '1' ----------------------------------------------------------------------------------------------------------- the configure file is the same as website. And when i checked the GEOMETRY file, it shows : ------------------------- Exit Success (SU2_GEO) ------------------------ OBJECTIVE_FUNCTION: invalid option value MAX_THICKNESS_SEC1. Check current SU2 options in config_template.cfg. ----------------------------------------------------------------------------------------- I think it is problem of the MAX_THICKNESS_SEC1 constraint cost this problem.But how could i fix it ? And it is all the same as the tutorial, it would don't have this problem. Does anyone kindly show me the way to fix it? Thanks in advance and for you kindly attention. |
December 16, 2016, 03:51 |
#2 | |
Heather Kline
Rep Power: 14 |
I was able to reproduce this error only by changing the configuration file to use MAX_THICKNESS_SEC1 as the OPT_OBJECTIVE selection - it worked fine when this was a constraint. At first glance, it looks like this is a current limitation, that the maximum section thickness can be used as a constraint, but not as an objective. Possibly this may be introduced in a later version of the code. If you would like a developer to look into that, you can introduce this as an issue on github, and if you are interested you are welcome to take on making the necessary modifications yourself as well. |
December 18, 2016, 07:05 |
#3 | |
JAMES
Rep Power: 9 |
Thanks for you kindly reply. I tried the run in another directory but it still occurs the same problem. The MAX_THICKNESS_SEC1 i used is the same as the tutorial sample as below: -------------------------------------------------------------------- % Optimization constraint functions with scaling factors, separated by semicolons % ex= (Objective = Value ) * Scale, use '>','<','=' OPT_CONSTRAINT= (LIFT > 0.2864) * 0.1; (MAX_THICKNESS_SEC1 > 0.0570) * 0.1; (MAX_THICKNESS_SEC2 > 0.0513) * 0.1; (MAX_THICKNESS_SEC3 > 0.0457) * 0.1; (MAX_THICKNESS_SEC4 > 0.0399) * 0.1; (MAX_THICKNESS_SEC5 > 0.0343) * 0.1 % ------------------------------------------------------------------------ Because i am a newer in using SU2. I'm really confused now. It would be great thanks if you kindly show me the way to fix this problem. And also could you plz show me where can i find the variable MAX_THICKNESS_SEC1 defined in the source? |
December 18, 2016, 16:52 |
Heather Kline
Rep Power: 14 |
What is in the option 'OPT_OBJECTIVE'?
It should not effect the shape_optimization.py script, but if 'OBJECTIVE_FUNCTION' is also in your config file, what option is used? What code version are you using? The options are defined in Common/include/option_structure.hpp and Common/src/config_structure.cpp. Some options are interpreted by the python scripts using functions defined in SU2_PY/SU2/io/tools.py and other scripts in that directory. |
December 18, 2016, 22:46 |
#5 | |
JAMES
Rep Power: 9 |
Thanks for you kindly and promotion reply. The version i am using is SU2 4.3.0. The Objective_function is as below mentioned in the .cfg file's Optimal shape design definition part: ------------------------------------------- % --------------------- OPTIMAL SHAPE DESIGN DEFINITION -----------------------% % Available flow based objective functions or constraint functions % DRAG, LIFT, SIDEFORCE, EFFICIENCY, % FORCE_X, FORCE_Y, FORCE_Z, % MOMENT_X, MOMENT_Y, MOMENT_Z, % THRUST, TORQUE, FIGURE_OF_MERIT, % EQUIVALENT_AREA, NEARFIELD_PRESSURE, % FREE_SURFACE % % Available geometrical based objective functions or constraint functions % MAX_THICKNESS, 1/4_THICKNESS, 1/2_THICKNESS, 3/4_THICKNESS, AREA, AOA, CHORD, % MAX_THICKNESS_SEC1, MAX_THICKNESS_SEC2, MAX_THICKNESS_SEC3, MAX_THICKNESS_SEC4, MAX_THICKNESS_SEC5, % 1/4_THICKNESS_SEC1, 1/4_THICKNESS_SEC2, 1/4_THICKNESS_SEC3, 1/4_THICKNESS_SEC4, 1/4_THICKNESS_SEC5, % 1/2_THICKNESS_SEC1, 1/2_THICKNESS_SEC2, 1/2_THICKNESS_SEC3, 1/2_THICKNESS_SEC4, 1/2_THICKNESS_SEC5, % 3/4_THICKNESS_SEC1, 3/4_THICKNESS_SEC2, 3/4_THICKNESS_SEC3, 3/4_THICKNESS_SEC4, 3/4_THICKNESS_SEC5, % AREA_SEC1, AREA_SEC2, AREA_SEC3, AREA_SEC4, AREA_SEC5, % AOA_SEC1, AOA_SEC2, AOA_SEC3, AOA_SEC4, AOA_SEC5, % CHORD_SEC1, CHORD_SEC2, CHORD_SEC3, CHORD_SEC4, CHORD_SEC5 % % Available design variables % HICKS_HENNE ( 1, Scale | Mark. List | Lower(0)/Upper(1) side, x_Loc ) % COSINE_BUMP ( 2, Scale | Mark. List | Lower(0)/Upper(1) side, x_Loc, x_Size ) % SPHERICAL ( 3, Scale | Mark. List | ControlPoint_Index, Theta_Disp, R_Disp ) % NACA_4DIGITS ( 4, Scale | Mark. List | 1st digit, 2nd digit, 3rd and 4th digit ) % DISPLACEMENT ( 5, Scale | Mark. List | x_Disp, y_Disp, z_Disp ) % ROTATION ( 6, Scale | Mark. List | x_Axis, y_Axis, z_Axis, x_Turn, y_Turn, z_Turn ) % FFD_CONTROL_POINT ( 7, Scale | Mark. List | FFD_BoxTag, i_Ind, j_Ind, k_Ind, x_Mov, y_Mov, z_Mov ) % FFD_DIHEDRAL_ANGLE ( 8, Scale | Mark. List | FFD_BoxTag, x_Orig, y_Orig, z_Orig, x_End, y_End, z_End ) % FFD_TWIST_ANGLE ( 9, Scale | Mark. List | FFD_BoxTag, x_Orig, y_Orig, z_Orig, x_End, y_End, z_End ) % FFD_ROTATION ( 10, Scale | Mark. List | FFD_BoxTag, x_Orig, y_Orig, z_Orig, x_End, y_End, z_End ) % FFD_CAMBER ( 11, Scale | Mark. List | FFD_BoxTag, i_Ind, j_Ind ) % FFD_THICKNESS ( 12, Scale | Mark. List | FFD_BoxTag, i_Ind, j_Ind ) % FFD_VOLUME ( 13, Scale | Mark. List | FFD_BoxTag, i_Ind, j_Ind ) % FOURIER ( 14, Scale | Mark. List | Lower(0)/Upper(1) side, index, cos(0)/sin(1) ) % % Optimization objective function with scaling factor % ex= Objective * Scale OPT_OBJECTIVE= DRAG * 0.1 % % Optimization constraint functions with scaling factors, separated by semicolons % ex= (Objective = Value ) * Scale, use '>','<','=' OPT_CONSTRAINT= (LIFT > 0.2864) * 0.1; (MAX_THICKNESS_SEC1 > 0.0570) * 0.1; (MAX_THICKNESS_SEC2 > 0.0513) * 0.1; (MAX_THICKNESS_SEC3 > 0.0457) * 0.1; (MAX_THICKNESS_SEC4 > 0.0399) * 0.1; (MAX_THICKNESS_SEC5 > 0.0343) * 0.1 % -------------------------------------------------------------------------- What's the tutorial's version?Maybe i should try that version to run the sample. |
December 19, 2016, 04:26 |
JAMES
Rep Power: 9 |
Finally, i used the SU2 version 4.2.0 and the problem is not exist. The sample could be run very well. So i think maybe is the 4.3.0 version difference caused this problem. I suggest the developer should use the 4.3.0 to run the inv_ONERAM6_adv.cfg to see if it is really exist this problem. Or it is only my computer's problem.
December 22, 2016, 10:35 |
Alejandro Quirós
Rep Power: 9 |
Hello.
I'm using the version 4.3 and I have the same issue while trying to run this tutorial. After a bit of research, I've found that it's not possible to use more than 2 constraints. When you use 2 constraints or more, in the config_GEO.cfg file that SU2 creates in the DESIGNS/DSN_XXX/GEOMETRY folder the OBJECTIVE_FUNCTION value is not the one stated in the cfg file but the second constraint stated in the OPT_CONSTRAINTS in the cfg. I have tried the tutorial using a different constraint to see if the problem was in the use of MAX_THICKNESS_SECX constraint, but the issue remains with any constraint that you use in second position. Maybe the problem could be in the script that reads the cfg file. Has it changed in the last version? Last edited by AQuiros; December 22, 2016 at 14:31. |
December 27, 2016, 00:14 |
Heather Kline
Rep Power: 14 |
Thank you all for testing the tutorial. I have not managed to reproduce the problem, but it looks like multiple people are seeing the same issue, and since it's one of the tutorials it would be good to fix it soon.
After some searching, the only thing that pops out at me is that there is a mismatch in names - in option_structure.hpp MAX_THICK_SEC* is listed, while in the python files 'MAX_THICKNESS_SEC*' is used. The fastest way to check would likely be to modify the python file SU2/bin/SU2/io/tools.py to replace every instance of 'THICKNESS' with 'THICK' and see if that fixes it. If anyone is willing to do that, please go ahead. If there continue to be issues, try the develop branch and/or go ahead and open an issue on github. If you find the source of the problem and fix it, please submit a pull request so that others can benefit. Its a bit confusing, since this name mismatch also occurs in version 4.2, but that could at least eliminate a possible cause. If you think you may submit a pull request, first check out the develop branch rather than the master branch prior to modifying the code, and take a look at the developer section in the github wiki. |
December 30, 2016, 07:45 |
#9 |
Alejandro Quirós
Rep Power: 9 |
I don't think that is causing the bug since I've had the same report with any constraint I use in second position. For example I've tried the tutorial changing MAX_THICKNESS_SEC1 with AREA_SEC1 and I got this message,
"OBJECTIVE_FUNCTION: invalid option value AREA_SEC1. Check current SU2 options in config_template.cfg." I think something is making the value of the OBJECTIVE_FUNCTION changes from its value in the config file to the value used for the second constraint in OPT_CONSTRAINT. |
December 31, 2016, 15:26 |
#10 | |
Heather Kline
Rep Power: 14 |
Just to narrow this down, can you try a non-geometric constraint in the second position? And, separately, try a geometric constraint in the first position? This will help narrow down whether this problem is coming from all the geometric constraints or from the processing of multiple constraints. (Geometric constraints = max thickness, area, etc, anything evaluated by SU2_GEO; non-geometric = lift, drag, moments, etc) What that error means is that 'AREA_SEC1' does not exist in the option_structure.hpp definition of the options available for that variable. A quick fix would be to simply add the options to the list in option_structure.hpp and recompile, however I do not think that is the right fix to do here. I had not previously spent much time with SU2_GEO - after looking more closely, I think now that what the python code SHOULD be doing is to NOT set the objective_function variable at all during the SU2_GEO step. SU2_GEO outputs the geometric quantities to a file and does not depend on the value in that option. So the question to answer now is why the code is incorrectly generating the config file for SU2_GEO in v4.3 - if it's because of a change to how multiple constraints are handled, or if it's because of a change to how geometric quantities are evaluated. |
January 5, 2017, 15:24 |
#11 |
Alejandro Quirós
Rep Power: 9 |
I have done a few tests today and I think now it's clear the bug is related to geometrical constraints.
WIth a non-geometrical constraint it runs well. With one geometrical constraint it crashes. With two constraints, one geometrical and one non-geometrical it crashes and it doesn't matter in what position they are. The value of OBJECTIVE_FUNCTION always changes from the value it should have, DRAG, to the value of the geometrical constraint. |
February 1, 2017, 18:10 |
#12 |
Heather Kline
Rep Power: 14 |
Hello
I am happy to announce that this problem has been fixed in SU2 version 5.0.0 'Raven'. |
February 3, 2017, 07:15 |
#13 |
Alejandro Quirós
Rep Power: 9 |
Thanks! I've used v5.0 and it's working properly.
Problem running tutorial | vrolin | OpenFOAM Installation | 6 | November 30, 2012 08:12 |
Problem running cavityGrade Tutorial | CFDMike | OpenFOAM Running, Solving & CFD | 0 | September 23, 2010 07:46 |
Problem in running tutorial cases | preetham | OpenFOAM Installation | 2 | June 13, 2009 16:36 |
problem when running icoFoam on a complex shape flow field | wendywu | OpenFOAM | 1 | May 20, 2009 23:40 |
Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 07:52 |
