November 29, 2016, 15:38 |
Nondimensional run
kowalski
Rep Power: 10 |
Hi all,
I am trying to run a supersonic inviscid case over a space shuttle using the FREESTREAM_PRESS_EQ_ONE option. I have issues with what is happening in the undisturbed region of the flow ahead the vehicle (see image attached). Point is that if I run DIMENSIONAL the same region looks OK, except that afterwards the simulation diverges due to nonphysical solution in the rear part of the shuttle. Before playing around with the mesh I would appreciate any comment on what could be wrong with my settings (see config file below) Please note that I am already at CFL 0.01, and running first order Thanks % ------------- DIRECT, ADJOINT, AND LINEARIZED PROBLEM DEFINITION ------------% % % Physical governing equations (EULER, NAVIER_STOKES) PHYSICAL_PROBLEM= EULER % % Mathematical problem (DIRECT, CONTINUOUS_ADJOINT) MATH_PROBLEM= DIRECT % % Restart solution (NO, YES) RESTART_SOL= NO % % ----------- COMPRESSIBLE AND INCOMPRESSIBLE FREE-STREAM DEFINITION ----------% % % Regime type (COMPRESSIBLE, INCOMPRESSIBLE) REGIME_TYPE= COMPRESSIBLE % % Mach number (non-dimensional, based on the free-stream values) MACH_NUMBER= 3 % % Angle of attack (degrees) AoA= 180 % % Side-slip angle (degrees) SIDESLIP_ANGLE= 0.0 % % Free-stream pressure (101325.0 N/m^2 by default, only for Euler equations) FREESTREAM_PRESSURE= 101325 % % Free-stream temperature (288.15 K by default) FREESTREAM_TEMPERATURE= 288 % % Reynolds number (non-dimensional, based on the free-stream values) %REYNOLDS_NUMBER= 9.E6 % % Reynolds length (1 m by default) %REYNOLDS_LENGTH= 1 % % ---- IDEAL GAS, POLYTROPIC, VAN DER WAALS AND PENG ROBINSON CONSTANTS -------% % % Different gas model (STANDARD_AIR, IDEAL_GAS, VW_GAS, PR_GAS) FLUID_MODEL= STANDARD_AIR % % Ratio of specific heats (1.4 default and the value is hardcoded % for the model STANDARD_AIR) GAMMA_VALUE= 1.4 % % Specific gas constant (287.058 J/kg*K default and this value is hardcoded % for the model STANDARD_AIR) GAS_CONSTANT= 287.058 % % Critical Temperature (131.00 K by default) CRITICAL_TEMPERATURE= 131.00 % % Critical Pressure (3588550.0 N/m^2 by default) CRITICAL_PRESSURE= 3588550.0 % % Critical Density (263.0 Kg/m3 by default) CRITICAL_DENSITY= 263.0 % % Acentric factor (0.035 (air)) ACENTRIC_FACTOR= 0.035 % % --------------------------- VISCOSITY MODEL ---------------------------------% % % Viscosity model (SUTHERLAND, CONSTANT_VISCOSITY). VISCOSITY_MODEL= SUTHERLAND % % Molecular Viscosity that would be constant (1.716E-5 by default) MU_CONSTANT= 1.716E-5 % % Sutherland Viscosity Ref (1.716E-5 default value for AIR SI) MU_REF= 1.716E-5 % % Sutherland Temperature Ref (273.15 K default value for AIR SI) MU_T_REF= 273.15 % % Sutherland constant (110.4 default value for AIR SI) SUTHERLAND_CONSTANT= 110.4 % % Specify turbulence model (NONE, SA, SA_NEG, SST) KIND_TURB_MODEL= SST % % --------------------------- THERMAL CONDUCTIVITY MODEL ----------------------% % % Conductivity model (CONSTANT_CONDUCTIVITY, CONSTANT_PRANDTL). CONDUCTIVITY_MODEL= CONSTANT_PRANDTL % % Molecular Thermal Conductivity that would be constant (0.0257 by default) KT_CONSTANT= 0.0257 % % ---------------------- REFERENCE VALUE DEFINITION ---------------------------% % % Reference origin for moment computation REF_ORIGIN_MOMENT_X = 0.25 REF_ORIGIN_MOMENT_Y = 0.00 REF_ORIGIN_MOMENT_Z = 0.00 % % Reference length for pitching, rolling, and yawing non-dimensional moment REF_LENGTH_MOMENT= 1.0 % % Reference area for force coefficients (0 implies automatic calculation) REF_AREA= 0 % % Flow non-dimensionalization (DIMENSIONAL, FREESTREAM_PRESS_EQ_ONE, % FREESTREAM_VEL_EQ_MACH, FREESTREAM_VEL_EQ_ONE) REF_DIMENSIONALIZATION= FREESTREAM_PRESS_EQ_ONE % % ----------------------- BOUNDARY CONDITION DEFINITION -----------------------% % % Marker of the surface which is going to be plotted or designed MARKER_PLOTTING= ( WING_UPPER, WING_LOWER, FUSELAGE, VERTICALFIN, NACELLE, RADOME, REAR, EXIT, SYMMETRYPLANE ) % % Marker of the surface where the functional (Cd, Cl, etc.) will be evaluated MARKER_MONITORING= ( WING_UPPER, WING_LOWER, FUSELAGE, VERTICALFIN, NACELLE, RADOME, REAR ) % % Euler wall boundary marker(s) (NONE = no marker) MARKER_EULER= ( WING_UPPER, WING_LOWER, FUSELAGE, VERTICALFIN, NACELLE, RADOME, REAR, SYMMETRYPLANE ) % % Navier-Stokes (no-slip), constant heat flux wall marker(s) (NONE = no marker) % Format: ( marker name, constant heat flux (J/m^2), ... ) MARKER_HEATFLUX= ( NONE ) % % Navier-Stokes (no-slip), isothermal wall marker(s) (NONE = no marker) % Format: ( marker name, constant wall temperature (K), ... ) MARKER_ISOTHERMAL= ( NONE ) % % Far-field boundary marker(s) (NONE = no marker) MARKER_FAR= ( NONE ) % % Symmetry boundary marker(s) (NONE = no marker) MARKER_SYM= ( NONE ) % % Zone interface boundary marker(s) (NONE = no marker) MARKER_INTERFACE= ( NONE ) % % Actuator disk boundary marker(s) (NONE = no marker) % Format: ( inlet face marker, outlet face marker, % rotation_angle_x-axis, rotation_angle_y-axis, rotation_angle_z-axis, % root radius, tip radius, pressure jump, temperature jump, rev/min, % uniform(0)/linear(1) distribution, ... ) MARKER_ACTDISK= ( NONE ) % % Inlet boundary type (TOTAL_CONDITIONS, MASS_FLOW) INLET_TYPE= TOTAL_CONDITIONS % % Inlet boundary marker(s) with the following formats (NONE = no marker) % Total Conditions: (inlet marker, total temp, total pressure, flow_direction_x, % flow_direction_y, flow_direction_z, ... ) where flow_direction is % a unit vector. % Mass Flow: (inlet marker, density, velocity magnitude, flow_direction_x, % flow_direction_y, flow_direction_z, ... ) where flow_direction is % a unit vector. % Incompressible: (inlet marker, NULL, velocity magnitude, flow_direction_x, % flow_direction_y, flow_direction_z, ... ) where flow_direction is % a unit vector. MARKER_INLET= ( NONE ) % % Supersonic inlet boundary marker(s) (NONE = no marker) % Format: (inlet marker, temperature, static pressure, velocity_x, % velocity_y, velocity_z, ... ), i.e. primitive variables specified. MARKER_SUPERSONIC_INLET= ( FARFIELD, 288, 101325, -1020.625, 0.0, 0.0 ) % % Outlet boundary marker(s) (NONE = no marker) % Format: ( outlet marker, back pressure (static), ... ) MARKER_OUTLET= ( NONE ) % % Supersonic outlet boundary marker(s) (NONE = no marker) MARKER_SUPERSONIC_OUTLET= ( EXIT ) % % Periodic boundary marker(s) (NONE = no marker) % Format: ( periodic marker, donor marker, rotation_center_x, rotation_center_y, rotation_center_z, rotation_angle_x-axis, rotation_angle_y-axis, rotation_angle_z-axis, translation_x, translation_y, translation_z, ... ) MARKER_PERIODIC= ( NONE ) % % Displacement boundary marker(s) (NONE = no marker) % Format: ( displacement marker, displacement value normal to the surface, ... ) MARKER_NORMAL_DISPL= ( NONE ) % % Pressure boundary marker(s) (NONE = no marker) % Format: ( pressure marker ) MARKER_PRESSURE= ( NONE ) % % Neumann bounday marker(s) (NONE = no marker) MARKER_NEUMANN= ( NONE ) % % Dirichlet boundary marker(s) (NONE = no marker) MARKER_DIRICHLET= ( NONE ) % % Riemann boundary marker(s) (NONE = no marker) % Format: (marker, data kind flag, list of data) MARKER_RIEMANN= ( NONE ) % % Non Reflecting boundary conditions marker(s) (NONE = no marker) % Format: (marker, data kind flag, list of data) MARKER_NRBC= ( NONE ) % % ------------- COMMON PARAMETERS TO DEFINE THE NUMERICAL METHOD --------------% % Numerical method for computation of spatial gradients: (GREEN_GAUSS, % WIEGHTED_LEAST_SQUARES) NUM_METHOD_GRAD= WEIGHTED_LEAST_SQUARES % % Courant-Friedrichs-Lewy condition of the finest grid CFL_NUMBER= 0.01 % % Adaptive CFL number (NO, YES) CFL_ADAPT= NO % % Parameters of the adaptive CFL number (factor down, factor up, CFL min value, % CFL max value ) CFL_ADAPT_PARAM= ( 1.5, 0.5, 0.5, 5.0 ) % % Runge-Kutta alpha coefficients RK_ALPHA_COEFF= ( 0.66667, 0.66667, 1.000000 ) % % Number of total iterations EXT_ITER= 1000000 % % Linear solver for the implicit formulation (BCGSTAB, FGMRES) LINEAR_SOLVER= FGMRES % % Min error of the linear solver for the implicit formulation LINEAR_SOLVER_ERROR= 1E-6 % % Max number of iterations of the linear solver for the implicit formulation LINEAR_SOLVER_ITER= 30 % % -------------------------- MULTIGRID PARAMETERS -----------------------------% % % Multi-Grid Levels (0 = no multi-grid) MGLEVEL= 3 % % Multi-grid cycle (V_CYCLE, W_CYCLE, FULLMG_CYCLE) MGCYCLE= W_CYCLE % % Multi-Grid PreSmoothing Level MG_PRE_SMOOTH= ( 1, 2, 3, 3 ) % % Multi-Grid PostSmoothing Level MG_POST_SMOOTH= ( 0, 0, 0, 0 ) % % Jacobi implicit smoothing of the correction MG_CORRECTION_SMOOTH= ( 0, 0, 0, 0 ) % % Damping factor for the residual restriction MG_DAMP_RESTRICTION= 1.0 % % Damping factor for the correction prolongation MG_DAMP_PROLONGATION= 1.0 % % -------------------- FLOW NUMERICAL METHOD DEFINITION -----------------------% % % Convective numerical method (JST, LAX-FRIEDRICH, CUSP, ROE, AUSM, HLLC, % TURKEL_PREC, MSW) CONV_NUM_METHOD_FLOW= ROE % % Spatial numerical order integration (1ST_ORDER, 2ND_ORDER, 2ND_ORDER_LIMITER) % SPATIAL_ORDER_FLOW= 1ST_ORDER % % Slope limiter (VENKATAKRISHNAN, MINMOD) SLOPE_LIMITER_FLOW= VENKATAKRISHNAN % % Coefficient for the limiter LIMITER_COEFF= 0.3 % % 1st, 2nd and 4th order artificial dissipation coefficients AD_COEFF_FLOW= ( 0.15, 0.5, 0.04 ) % % Time discretization (RUNGE-KUTTA_EXPLICIT, EULER_IMPLICIT, EULER_EXPLICIT) TIME_DISCRE_FLOW= EULER_IMPLICIT % % --------------------------- CONVERGENCE PARAMETERS --------------------------& % % Convergence criteria (CAUCHY, RESIDUAL) CONV_CRITERIA= RESIDUAL % % Residual reduction (order of magnitude with respect to the initial value) RESIDUAL_REDUCTION= 6 % % Min value of the residual (log10 of the residual) RESIDUAL_MINVAL= -6 % % Start convergence criteria at iteration number STARTCONV_ITER= 100 % % Number of elements to apply the criteria CAUCHY_ELEMS= 100 % % Epsilon to control the series convergence CAUCHY_EPS= 1E-10 % % Function to apply the criteria (LIFT, DRAG, NEARFIELD_PRESS, SENS_GEOMETRY, % SENS_MACH, DELTA_LIFT, DELTA_DRAG) CAUCHY_FUNC_FLOW= DRAG % |
fatal overflow error in the FINMES subroutine for CHT run | prashant79_ss | CFX | 5 | September 27, 2014 05:54 |
Cannot run phoenix on linux opensuse 13.1 kde | mabal | Phoenics | 0 | June 15, 2014 07:16 |
[mesh manipulation] Cannot get refineMesh to run in parallel | smschnob | OpenFOAM Meshing & Mesh Conversion | 2 | June 3, 2014 12:20 |
First Parallel Run - need some help | Gian Maria | OpenFOAM | 3 | June 17, 2011 13:08 |
Windows 64-bit, Distributed Parallel Run Issues... | Erich | CFX | 3 | March 28, 2006 17:36 |
