Home > Forums > Software User Forums > SU2
Is SU2 able to handle adjoint for pressure distribution when doing inverse design?
Old   November 23, 2016, 01:40
Post Is SU2 able to handle adjoint for pressure distribution when doing inverse design?
Xiaosong
Xiaosong is on a distinguished road
Hi all,
I am doing pressure inverse design using SU2. It will speed up the computation if adjoint could be added. I know SU2 can handle adjoint for Cd and Cl, and also find that objective function could be set as inverse_design_pressure in SU2. So, I am just wondering whether I can do adjoint for this, as well, just like that for Cd and Cl.
Thanks for the patience! Any comments are very welcome!
Thanks,
Xiaosong
Xiaosong is offline   Reply With Quote
Old   December 4, 2016, 01:15
hlk
Heather Kline
hlk is on a distinguished road
Originally Posted by Xiaosong View Post
Hi all,
Thanks,
Xiaosong
Yes, it can.
Set the appropriate objective function, and run the adjoint as you would for Cd or Cl.
See example in TestCases/optimization_euler/steady_inverse_design/ - note that config file and mesh/target cp files are in the su2code/SU2 and su2code/TestCases repositories respectively:
https://github.com/su2code/SU2/tree/...inverse_design
https://github.com/su2code/TestCases...inverse_design
hlk is offline   Reply With Quote
Old   December 4, 2016, 01:25
Xiaosong
Originally Posted by hlk View Post
Yes, it can.
OK! I see! Thank you very much for your reply!
Actually, I have already tried that test case, and started building up my own cases.
For now, I get one more question:
in source code, the objective function = SUM{area * (cp - cp_target) * (cp - cp_target)}, where area is obtained from modulus of normal vectors of each small segment on airfoil. But each node will have two lines sharing it, which arc should we take into the formula, please?
Thanks,
Xiaosong
adjoint, inverse design, pressure distribution, su2
Inverse design Seroga Main CFD Forum 0 April 8, 2008 02:58
Collaboration on continuous adjoint design optimiz Carlos Lozano Main CFD Forum 0 April 4, 2008 05:13
Inverse design and Optimization of Aircraft Wings Simon Nava Main CFD Forum 8 May 22, 2007 15:55
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 08:10
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 11:18
