Akshay Deshpande
Rep Power: 11 ![]() |
Hi all,
I have a couple of questions regarding mesh refinement and mesh adaptation in SU2. 1] Does SU2 support a grid with 2:1 refinement ratio - thereby leading to the presence of hanging nodes? I have refined my mesh at the location of the applied source term to better resolve it. A picture is attached below. ![]() 2] I am trying to use the mesh adaptation code in SU2. For that, I am running the SU2_MSH binary for a restart file at a particular time-step (not converged). This gives me a new mesh file - which I use to run my case from the beginning. Is this the correct approach? 3] Is it possible to perform grid based interpolation in SU2? Thanks in advance! |
Oliver V
Rep Power: 10 ![]() |
Hello, I'm interested in this answer too.
[snappyHexMesh] SnappyHexMesh running killed! | Mark JIN | OpenFOAM Meshing & Mesh Conversion | 7 | June 14, 2022 01:37 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
killed "snappyHexMesh" | parkh32 | OpenFOAM Pre-Processing | 2 | April 8, 2012 17:12 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 03:23 |
