Home > Forums > Software User Forums > SU2
Restart to adjoint for Unsteady Turbulence Cylinder flow
Old   October 7, 2016, 15:50
Default Restart to adjoint for Unsteady Turbulence Cylinder flow
Yu-Kai Weng
yweng3 is on a distinguished road
Hello everyone,
I am learning to use SU2 for my CFD research. Currently, I have a set of the Unsteady Turbulence Cylinder flow from direct method.
However when I edit the .cfg file to restart the adjoint simulation. Then the error message comes up: "Requesting a negative iteration number for the restart file!!"
Based on the previous post with the same issue, if I want to restart simulation from the very beginning even I have done 5000 timesteps simulation from the direct method. I shall set UNST_RESTART_ITER=2, then SU2 will read solution_flow_00000.dat and solution_flow_00001.dat and restart the simulation by continuous adjoint method. But somehow it doesn't work.
Then I go back to run Quickstart case to see if there is anything related the software configuration or setting, when I start to run adjoint, the error message shows up again:" There is no adjoint restart file!! solution_adj_cd.dat."
It looks like maybe my SU2 cannot read the solution file correctly to restart the adjoint simulation. But it's just a guess.
It will be very appreciated if anyone can help. The .cfg file for my cylinder flow simulation is attached.
yweng3 is offline   Reply With Quote
Flow past a 2D cylinder - High Re (1E+05) - Cd too high Pervispasco OpenFOAM Running, Solving & CFD 4 March 14, 2022 03:19
Keeping intermediate files OVS SU2 5 December 5, 2021 12:41
[ImmersedBoundary] Immersed Boundary: Turbulence flow around a cylinder sina_mech OpenFOAM Community Contributions 2 December 3, 2019 12:17
Turbulence postprocessing Mohsin FLUENT 2 October 3, 2016 15:18
flow over cylinder pang FLUENT 0 November 21, 2008 03:27
