October 4, 2016, 09:16 |
Adapted mesh diverge
Alberto Pizarro
Rep Power: 10 |
I'm using SU2 for 3D simulations with 8M elements. I'm trying to use mesh_adaptation.py. But SU2 diverges when I run it again with mesh_out.su2 The size of mesh_out.su2 file is 604MB and of restart_flow.dat 476MB only. There is a very high decrease from the initial mesh and restart files before the grid adaption. They were around 1.1-1.5Gb. I tried to change: ADAPT_BOUNDARY= to NO and SMOOTH_GEOMETRY= to NO But it keeps diverging. Could anyone say me what have i doing wrong? Thx. Alberto. Last edited by AlbertoPi; October 5, 2016 at 13:38. |
October 6, 2016, 20:00 |
#2 | |
Heather Kline
Rep Power: 14 |
The output mesh file size should be very close to the initial mesh file. I'm not sure what the problem is, but the first thing I think of is to check to make sure that WRT_VOL_SOL = YES (YES is the default value used if this option is not included in your config file). When you say it diverges, does it run a few iterations and then diverge? Are there any other error messages output? If it is simply that it starts running ok for a few iterations and then diverges eventually, you may need to decrease the CFL number and/or check that the output mesh is not doing something weird like producing negative-volumed cells. |
October 10, 2016, 08:54 |
#3 | |
Alberto Pizarro
Rep Power: 10 |
My config file didn't include WRT_VOL_SOL value. I tried to use it with YES value and it was still diverging. The simulation begins ok, and after a "few" iterations the CLift gets up to -1000 and CDrag up to 1000 slowly and then appears the message "SU2 has diverged". I have no messages about no-physical points. I use CFL=1. The original mesh file is in CGNS format and has 255Mb. The mesh_out.su2 file has 605Mb. And in my expiriences the SU2 format is much heavier than CGNS. The original solution_flow.dat file is 1.5Gb and the restart file after grid adaptation is 476.7Mb. If i use, after the adaptation, the SU2_SOL to ckeck flow.vtk file, it hasn't values about the flow. Now I tried to use the mesh_out.su2 without the restart options to check only the mesh, and it works right. So, I can't use the restart file after the grid adaptation. Thanks again. Cheers. Alberto |
October 10, 2016, 13:04 |
#4 | |
Heather Kline
Rep Power: 14 |
Based on the additional details, it sounds like there is enough of a change between the initial and adapted mesh to make the restart solution far enough off that starting from scratch was a more stable computation. You can try using the CFL adaptation parameters with a minimum CFL less than 1 if you prefer to use the restart files. (See http://www.cfd-online.com/Forums/su2...parameter.html) |
October 11, 2016, 08:50 |
#5 | |
Alberto Pizarro
Rep Power: 10 |
I wasn't sure if my mesh.out was smaller that the initial mesh because the initial mesh is in CGNS format. Now i know that it's ok. But the new solution_flow.dat doesn't contain results. I have attached screenshot of the strange values that i see in paraview. I appreciate a lot your help |
diverged, mesh_adaptation.py, su2 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
engrid -> save as .stl with boundarie codes | Zymon | enGrid | 31 | August 29, 2011 13:40 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
