September 19, 2016, 07:21 |
3D FSI not working parallel in version 4.3.0
shiva
Rep Power: 10 |
Dear Sir/Madam,
I am tying to run 3d FSI case its giving following error ..anybody help? ------------------------------ Begin Solver ----------------------------- Deforming the grid for Fluid-Structure Interaction applications. Deforming the volume grid. Computing volumes of the grid elements. Min. volume: 1.13247e-10, max. volume: 0.00993043. Computing distances to the nearest deforming surface. Min. distance: 1e+10, max. distance: 1e+10. CSysSolve::FGMRES(): system solved by initial guess. Computing volumes of the grid elements. Non-linear iter.: 1/1. Linear iter.: 0. Min. volume: 1.13247e-10. Error: 0. The mesh is up-to-date. Using previously stored grid velocities. Min DT: 1.62681e-07.Max DT: 0.000147022.Dual Time step: 0.001. ----------------------- Residual Evolution Summary ---------------------- log10[Maximum residual]: -0.499349. Maximum residual point 3219, located at (0.479036, 0.0401053, -0.00538081). Maximum Omega 41030.2, maximum Strain Rate 41322.2. ------------------------------------------------------------------------- IntIter ExtIter Res[Rho] Res[nu] CLift(Total) CDrag(Total) 0 0 -1.665264 -8.314481 -0.005869 0.119011 1 0 -0.389705 -8.141512 -0.008559 0.198427 2 0 -0.415118 -8.181613 -0.010810 0.276012 3 0 -0.444774 -8.222733 -0.012980 0.350797 4 0 -0.478435 -8.264554 -0.015294 0.421895 5 0 -0.515811 -8.306636 -0.017878 0.488540 6 0 -0.556583 -8.348944 -0.020638 0.550058 7 0 -0.600324 -8.390960 -0.023435 0.605806 8 0 -0.646508 -8.432178 -0.026802 0.655256 9 0 -0.694479 -8.472257 -0.030778 0.698099 9 0 -0.694479 -8.472257 -0.030778 0.698099 APPLICATION TERMINATED WITH THE EXIT STRING: Segmentation fault (signal 11) May I know is parallelization for FSI simulations is implemented in 4.3.0 or not? Thanks |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel | JR22 | OpenFOAM Running, Solving & CFD | 2 | April 19, 2013 16:49 |
i have problem with parallel version of fluent | greeneye | FLUENT | 0 | November 3, 2009 06:28 |
So Nobody Out There Working on FSI Methods | JD | Main CFD Forum | 3 | April 12, 2001 07:21 |
Parallel version of SIP ? | Ravikanth Avancha | Main CFD Forum | 1 | March 19, 1999 14:21 |
