wrong drag and skin friction for a flatplate test case |
September 7, 2016, 10:25 |
Boudigues Kevin
Rep Power: 10 |
Hi All,
I created my mesh for a flatplate similar to the flatplate named mesh137x97.su2 with a Y+ around 50. This mesh is created with Gmsh and converted in su2 file. When I compute with my mesh, I have a very low drag around [0.000035;0.00004] and my skin friction is very low too. Moreover, when I visualize the flow.vtk file with Paraview, I have a eddy visosity thicker than the eddy viscosity on the mesh137x97.su2. It is a problem of the fortran code who's converted the mesh or a problem due to Y+. I will be so thankful if you can help me Best Regards PS : if you need the mesh file or the file which can read by paraview, please give me your email. |
September 8, 2016, 03:32 |
I had a similar result when my y+ value was in the wall function regime, using a y+ around 1 fixed this. Regards, Tom |
September 8, 2016, 04:49 |
Boudigues Kevin
Rep Power: 10 |
Yes, i know with a Y+ around 1 or less, I can have good result but my aim is to find a solution for the value of Y+ around 50. So, if I understand, it is a problem with the size of the first cell in the mesh ? Best regards Kevin |
September 8, 2016, 05:11 |
I know there has been a project to incorporate wall functions, but as far as I know there is no final version yet. So until something like that is integrated in SU2 I do not think you can expect to have good results without near wall resolution of your mesh.
September 8, 2016, 08:38 |
Boudigues Kevin
Rep Power: 10 |
I understand.
Thank you for your time. Best regards |
skin friction and pressure Drag | kr63 | Tecplot | 0 | June 5, 2015 02:57 |
the skin friction coefficient in Fluent | GJ_hit | FLUENT | 3 | April 15, 2013 08:08 |
