August 31, 2016, 23:23 |
Restarted run changes residual evolution log
Paul Zhang
Rep Power: 15 |
Restarted a run and found that the residuals' scale changed a lot in the Residual Evolution Summary (for example Res[Rho]), and not consistent with the ones of the ending point from previous run.
Issue solved. It is related to the case. Mesh is too coarse, and oscillation is found. Last edited by paulzhang; September 1, 2016 at 02:35. |
chtMultiRegionSimpleFoam: maximum number of iterations excedeed. | Nkl | OpenFOAM Running, Solving & CFD | 19 | October 10, 2019 02:42 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
Cannot run the code properly: very large time step continuity error | crst15 | OpenFOAM Running, Solving & CFD | 9 | December 14, 2014 18:17 |
Why RNGkepsilon model gives floating error | shipman | OpenFOAM Running, Solving & CFD | 3 | September 7, 2013 08:00 |
Problems with simulating TurbFOAM | barath.ezhilan | OpenFOAM | 13 | July 16, 2009 05:55 |
