June 10, 2016, 13:32 |
SU2 Tutorial w/Multigrid Error
Dominique
I am having trouble running the first tutorial of SU2 (Inviscid Euler). For some reason the Multigrid is causing the code to stop running. Below is the last section of the log file:
------------------------- Geometry Preprocessing ------------------------ Setting point connectivity. Renumbering points (Reverse Cuthill McKee Ordering). Recomputing point connectivity. Setting element connectivity. Checking the numerical grid orientation. Identifying edges and vertices. Computing centers of gravity. Setting the control volume structure. Area of the computational grid: 1.25e+03. Searching for the closest normal neighbors to the surfaces. Compute the surface curvature. Max K: 7.84e+03. Mean K: 34.8. Standard deviation K: 494. Setting the multigrid structure. Has anyone else had this or a similar problem? |
July 6, 2016, 23:01 |
Andrew
Rep Power: 11 |
Are you running in parallel? If you try to run it using too many processors then that can make it really slow. I'd recommend using your number of processors minus one or two (I use 6, since my computer has 8).
Also, for me that step has taken a while (on the order of a couple minutes) for really computationally heavy tasks. However since you're running a tutorial mesh I don't think that'd be the issue. Unfortunately I can't offer much else, since I've never had it completely stop at that step. |
multigrid, su2, su2 error |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 10:00 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 08:24 |
POSDAT problem | piotka | STAR-CD | 4 | June 12, 2009 09:43 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 03:32 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 07:31 |
