Home > Forums > Software User Forums > SU2
RANS cases not converging in SU2 for Delta wing fighter aircraft configuration.
Old   June 1, 2016, 02:32
Default RANS cases not converging in SU2 for Delta wing fighter aircraft configuration.
Simm
kulls is on a distinguished road
Hi Friends,
This problem involves a delta wing fighter aircraft configuration.
Initially i ran some cases(Mach = 0.7 , AoA : 0 to 16 deg., Beta = 0 ) for EULER equations using SU2 code.The convergence achieved was of the order of 5 - 8 order.Results were in close agreement with other solvers..
I tweaked the .cfg file for RANS cases but its not working.
i'm trying to run RANS cases for the same flow condition and same geometry but not able to achieve convergence in any case.
I request everyone to put some useful comments.
Thanks!
Thanks!!
kulls is offline   Reply With Quote
Old   June 1, 2016, 08:32
Tom
mlooti is on a distinguished road
Hi
what is your mesh and config options?
It is hard to use the same mesh for Euler and RANS
you can upload the mesh and config file so one can take a look at it
mlooti is offline   Reply With Quote
Old   June 2, 2016, 07:36
Default Grid Detail and configuration file
Simm
Hi
I have generated unstructred Euler grid (surface tri and volume tetra)
and hybrid NS grid ( surface tri's , volume tetras, prisms and pyramid's).
The configurations files are tweaked for Euler and NS case .
In fact, in order to get the converged solution ,i tried various combinations of options available in the .cfg file but nothing worked till now as far as RANS cases are concerned.
I'm uploading the .cfg files for Euler and NS cases and grid details.
Plz share your comments !
Thanks!
Eul-m07a0b0-cfg.txt
NS-sa-m07a0b0-cfg.txt
grid-details-log.txt
Thanks!!
Old   June 13, 2016, 17:46
balugowda is on a distinguished road
I am also facing the same problem. At higher angle of attacks the, the solution does not converge. (similar farfield conditions: AOA- 0 - 15, 0.8 Mach, turbulent model - SA, for a BWB aircraft)
Does anyone have any suggestions ?
I tried the following:
1- MG-0, tried without the multigrid option to check if that is the problem, but it is not in my case.
2- CFL number - Tried to play with automatic CFL number varying from 1-10, but does not converge.
Please help !
Thanks!
balugowda is offline   Reply With Quote
.cfg, convergence problem, rans, su2
Ffd_control_point_2d feiyi SU2 4 September 30, 2019 13:42
