Eran Arad
Rep Power: 11 ![]() |
In a parallel SU2 run (using parallel_computation.py) on many compute nodes:
Is there a way to stop the run in a peaceful manner (that is, not ctrl C but in a way that all output and restart files are collected and written down before exit). Common practices are sending a kill command with parameters to one of the compute nodes, or touching a file with a pre-coded name (like killSU2) in the running folder, that once located, initiate ordered run termination. Could not trace any structure of that kind in the source. Did I miss something ? Thanks Eran |
Tim Albring
Rep Power: 10 ![]() |
Hi Arad,
you can create a file "runtime.dat" in the working folder to set the new number of external iterations (so just one line "EXT_ITER=..."). |
Eran Arad
Hi Talbring
Your suggestion worked nicely for direct solution. However, in optimization run, using shape_optimization.py script, the runtime.dat file had no effect. i have set there FFD_ITERATIONS, FFD_TOLERANCE and EXT_ITER but none was read or had an effect on the running job. Is there other way to control an optimization run ? Thanks |
jit
I have similar situation, where I have to stop CFD solver at particular iteration and import new surface gird file and continue running CFD solver with new file
Martin Simon
Did anyone get the solution for the mp optim run?
Rep Power: 12 ![]() |
Hey Arad,
if you put the runtime.dat file into the folders : DESIGNS/0.../DIRECT/ or DESIGNS/0.../ADJOINT/ it should work ... at least EXT_ITER= ... works to finish the direct or the adjoint computation ... but it will proceed the optimization procedure .... cheers |
run-time, terminate |
stop when I run in parallel | Nolwenn | OpenFOAM | 36 | March 21, 2021 04:56 |
How to run SU2 on cluster of computers (How to specify nodes ?) | aero_amit | SU2 | 29 | February 24, 2020 13:44 |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 04:18 |
Some questions about a multi region case run in parallel | zfaraday | OpenFOAM Running, Solving & CFD | 5 | February 23, 2017 10:25 |
Transient run continues from last time (when startover is desired) | bongbang | CFX | 2 | March 22, 2015 23:05 |
