Home > Forums > Software User Forums > SU2
All zeros: Skin Friction Coefficient, Heat Flux, Y Plus
Old   May 24, 2016, 02:38
Default All zeros: Skin Friction Coefficient, Heat Flux, Y Plus
Data C
LetsCFD is on a distinguished road
I run one of the the SU2 Edu example airfoils: airfoil_naca4412_selig.dat, default configuration, and RANS.
After a successful run, I open the flow.vtk and find the scalars Skin_Friction_Coefficient, Heat_Flux, and Y_Plus have the first value as non-zero and the rest of them are zeros.
Is that normal?
All other scalars seem to be correct.
Thanks.
LetsCFD is offline   Reply With Quote
Old   June 18, 2016, 12:12
hlk
Heather Kline
hlk is on a distinguished road
Is that normal?
Thanks.
Thanks for the question
There was an issue with the paraview format recently which was fixed, so the most recent release may help.
However, this could also be due to the surface marker: if you set the boundary as MARKER_EULER, it will be a slip wall which will have zero skin friction. For a no-slip wall the boundary condition should be heatflux (with heatflux set at 0 for adiabatic) or isothermal.
hlk is offline   Reply With Quote
heat flux, skin friction coefficient, su2 edu, y plus
Skin Friction Coefficient FrenchyTim FLUENT 10 January 15, 2018 11:41
Monitor Heat Flux in CFD-Pre cltormar CFX 5 November 20, 2014 12:45
Radiation interface hinca CFX 15 January 26, 2014 18:11
User wall heat flux coefficient specification crevoise STAR-CCM+ 0 January 15, 2014 09:26
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
