Home > Forums > Software User Forums > SU2
QuickStart gradients at low Mach numbers
Old   May 11, 2016, 17:09
Default QuickStart gradients at low Mach numbers
Ryan Barrett
Ry10 is on a distinguished road
For the QuickStart files I got the lift and drag gradients to match up fairly well between adjoint method and finite difference using a Mach number of 0.8. However, the lower the mach number the farther apart the drag gradients got between adjoint and finite difference. For a Mach number of 0.15 the lift gradients were still fine but the drag gradients were orders of magnitude off and even in some cases the wrong sign. Why does the accuracy of the drag gradients compared to finite difference depend so much on the Mach number? And how can I get good gradients at low Mach numbers? I have tried the incompressible TestCases but I haven't been able to get the drag gradients to match either.
Ry10 is offline   Reply With Quote
su2
Low mach number flat plate Zen SU2 1 October 6, 2014 07:59
About compressible flow at low mach hit Main CFD Forum 2 October 26, 2009 22:21
Development of a Low mach PISO solver nishant_hull OpenFOAM Programming & Development 0 August 25, 2009 13:48
TVD scheme at low Mach number Axel Rohde Main CFD Forum 5 August 6, 1999 03:01
how calculate the density in low mach number? Juhee Lee Main CFD Forum 1 July 31, 1999 16:26
