Home > Forums > Software User Forums > SU2
cont_adj_incomp_euler Test Case has wrong drag gradients
Old   May 10, 2016, 11:41
Default cont_adj_incomp_euler Test Case has wrong drag gradients
Ryan Barrett
Ry10 is on a distinguished road
I tried the NACA0012 test case in the TestCases/cont_adj_incomp_euler/naca0012 folder. The lift gradients match fairly well to finite difference. But the drag gradients are off by several orders of magnitude and in several cases the sign as well. Why would the test case be off by so much and what can be done to fix it? Thanks!
Ry10 is offline   Reply With Quote
su2 gradients
wrong SU2 calculation for lift and drag coefficient for NAC4421 mechy SU2 7 January 9, 2017 06:18
udf error srihari FLUENT 1 October 31, 2016 15:18
Drag prediction workshop 4 test case WBH iH = 0 Abhii SU2 1 October 3, 2013 02:22
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Fluent validation test for calculate the drag of a car ostervi FLUENT 0 June 12, 2009 13:59
