Home > Forums > Software User Forums > SU2
NACA0012 aeroelastic problem
Old   May 4, 2016, 22:29
Default NACA0012 aeroelastic problem
dark001001 is on a distinguished road
I ran a NACA0012 aeroelastic test from a steady result and reached a divergence. The config is like below.
The parameters of the steady flow calculation almost the same as the aeroelastic test except the parameters of UNSTEADY_SIMULATION.
BTW, what's the meaning of MACH_MOTION, any difference to the MACH_NUMBER?
dark001001 is offline   Reply With Quote
Old   June 5, 2016, 14:14
Cleber Spode
cspode is on a distinguished road
Dear,
For the aeroelastic case, the free-stream temperature is updated internally, see solver_direct_mean.cpp to match the flutter speed index and other aeroelastic input variables:
TgammaR = ((vf*vf)*(b*b)*(w_alpha*w_alpha)*mu) / (Mach*Mach);
You need to run your steady state with the same temperature and add two collumns in the solution_flow_00000.dat and solution_flow_00001.dat regarding grid velocities to restart properly. You can set Grid velocities to zero to start from rest.
Best.
cspode is offline   Reply With Quote
su2 error
conduction problem venkataramana OpenFOAM 3 December 1, 2013 08:30
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
Problem with airflow over naca0012 and angle o f attack Lucas OpenFOAM Running, Solving & CFD 2 February 18, 2011 14:13
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
