Home > Forums > Software User Forums > SU2
Frozen viscosity option not listed in configuration template files
Old   April 27, 2016, 13:05
Default Frozen viscosity option not listed in configuration template files
OSE
Jason Monschke
OSE is on a distinguished road
I noticed an option for frozen viscosity in the turb_SA_RAE2822.cfg test file:
% Adjoint frozen viscosity (NO, YES)
FROZEN_VISC= YES
This thread from a few years ago says that this option turns the adjoint turbulence model on and off which may affect convergence:
Setting the frozen viscosity to NO will enable the adjoint turbulence model (S-A) that is implemented in the code.
However, when I looked in the config_template_basic.cfg and config_template.cfg files I could not find this option. Is use of the frozen viscosity option not recommended?
Thanks,
Jason Monschke
EDIT: I should also mention that I'm using SU2 v4.1.2.
OSE is offline   Reply With Quote
configuration, frozen viscosity, input, options
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Compression stoke is giving higher pressure than calculated nickjuana CFX 62 May 19, 2015 14:32
Radiation Modeling Chris89 CFX 20 August 14, 2014 08:51
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
