The discrete adjoint method uses too large memory. |
April 26, 2016, 12:31 |
Yeongmin Jo
Rep Power: 12 |
Dear SU2 developers,
Hi, I'm testing the discrete adjoint method implimented in SU2 v4.1. When I try to use the method for RANS computation with k-w SST turbulence model and a grid with a total of 0.6 million points, the computation uses over 130Gb memory, so it is directly stopped as the amount is over the physical memory. The pure CFD computation uses about 20Gb, and the continuous adjoint method uses about 27Gb. Is that a normal situation, because the discrete adjoint is based on the external AD? Or, is there any memory leak? Thank you in advance. Last edited by Yminjo; April 26, 2016 at 23:25. |
April 27, 2016, 10:52 |
Tim Albring
Rep Power: 11 |
Hi Yeongmin,
the discrete adjoint solver takes about 4-7 times more memory than the flow solver. But 20GB for 0.6 Mio points for the pure CFD computation seems to be way to high. Are you sure about these numbers ? Tim |
Problems launching adjoint | max_ | SU2 | 2 | March 12, 2016 11:32 |
Help for learning about Adjoint Method in optimization | EmadTandis | Main CFD Forum | 0 | March 15, 2013 04:55 |
Adjoint method for shape optimization | Edris | Main CFD Forum | 6 | November 1, 2012 08:10 |
Anybody has CFD codes used Discrete Vortex Method | LuckyJ | Main CFD Forum | 7 | August 6, 2004 07:48 |
Discrete element method? | Ki Ha Hong | Main CFD Forum | 1 | May 28, 1999 09:46 |
