Home > Forums > Software User Forums > SU2
Code capability for hypersonic flow case TNE2
Old   April 12, 2016, 23:04
Default Code capability for hypersonic flow case TNE2
Paul Zhang
paulzhang is on a distinguished road
I am testing the capability of SU2 by solving a simple Argon flow over the RAMC in hypersonic flow regime. Got some errors after submitting the case as follows:
GAS_MODEL: invalid option name. Check current SU2 options in config_template.cfg.
REF_PRESSURE: invalid option name. Check current SU2 options in config_template.cfg.
REF_TEMPERATURE: invalid option name. Check current SU2 options in config_template.cfg.
REF_DENSITY: invalid option name. Check current SU2 options in config_template.cfg.
CONV_NUM_METHOD_TNE2: invalid option name. Check current SU2 options in config_template.c
So I guess the new version of code SU2 does not support the case anymore right? What can I do?
Thanks,
Paul
paulzhang is offline   Reply With Quote
Old   April 22, 2016, 03:18
Francisco Palacios
fpalacios is on a distinguished road
Dear Paul,
Unfortunately the TNE2 capability is not supported anymore and the implementation is incomplete.
The github branch feature_AdjTNE2 was the most updated one. It would be great if you want to work on this topic. If the answer is yes, then the best starting point is feature_AdjTNE2.
Best,
Francisco
fpalacios is offline   Reply With Quote
Old   April 22, 2016, 06:39
Paul Zhang
Dear Francisco,
Thanks so much for your clarification and that really helps to make life easier. I will check out that branch and try to see how it works. I will let you know if I make some progress.
Best,
Paul
Pressure Driven Supersonic Flow in Converging-Diverging Nozzle cdm OpenFOAM Running, Solving & CFD 7 August 28, 2019 02:37
Fortran code for laminar flow around naca0012 airfoil kianoosh_py Main CFD Forum 19 September 13, 2015 07:19
parallel code samiam1000 SU2 3 March 25, 2013 05:55
is there any parallel code for the famous Lid Driven Cavity flow? gholamghar Main CFD Forum 0 August 1, 2010 02:55
Validation case for turbulent flow Ratan Main CFD Forum 0 October 4, 2005 04:02
