Home > Forums > Software User Forums > SU2
Heatflux and isothermal boundary condition for incompressible formulation
Old   April 11, 2016, 09:18
Default Heatflux and isothermal boundary condition for incompressible formulation
Anant Diwakar
anant.diwakar is on a distinguished road
Hi all,
I want to simulate an incompressible channel flow with heatflux at the wall.
The temperature is always zero for any value of heatflux value in the
MARKER_HEATFLUX.
Is heatflux boundary condition not implemented for incompressible simulation ?
Thanks
Anant
anant.diwakar is offline   Reply With Quote
Old   April 12, 2016, 11:43
Ole Burghardt
Sprotte is on a distinguished road
Hi Anant,
within the incompressible setting, the flow solver does not incorporate the energy equation since temperature wouldn't influence the pressure and momentum variables anyway.
You could use estimates for the heat flux just depending on the flow solution (that is, without knowing the temperature field), e.g. the boundary layer ones that use the shear stress values on the boundary.
As far as I'm concerned, there are a lot of different approaches then. The easiest is the one for laminar flows, where the heat flux is approximately given by the product of shear stress times specific heat.
Regards,
Ole
Sprotte is offline   Reply With Quote
