Home > Forums > Software User Forums > SU2
Ordering of the sequence of loops over the edges and nodes
Old   March 27, 2016, 22:16
Default Ordering of the sequence of loops over the edges and nodes
Paul Zhang
paulzhang is on a distinguished road
This is Paul Zhang. I got a question on page 5-6 when I read the paper "Towards High-Performance Optimizations of the Unstructured Open-Source SU2 Suite", where I am a little confused about when to apply boundary conditions on the boundary node.
As far as I know, should the boundary conditions be imposed in the very beginning instead of step 3, so the convective and diffusive fluxes can be evaluated using that when we approach boundaries?
Thanks,
Paul
paulzhang is offline   Reply With Quote
Old   March 31, 2016, 01:54
Francisco Palacios
fpalacios is on a distinguished road
In SU2 we the weak formulation (boundary conditions are imposed via the residual). and we typically add the missing part flux form the exterior to the interior of the domain at the end (after computing internal fluxes).
This subroutine
void CIntegration::Space_Integration(CGeometry *geometry,
CSolver **solver_container,
CNumerics **numerics,
CConfig *config, unsigned short iMesh,
unsigned short iRKStep,
unsigned short RunTime_EqSystem) {
in integration_structure.cpp
could be useful for you.
Best,
Francisco
fpalacios is offline   Reply With Quote
[ICEM] Assigning different number of nodes to parallel edges Rohit ANSYS Meshing & Geometry 3 September 22, 2017 10:16
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
[ICEM] Nodes on Edges... RodriguezFatz ANSYS Meshing & Geometry 2 November 22, 2012 14:02
[ICEM] Nodes on sides of the edges don't match Attesz ANSYS Meshing & Geometry 1 February 10, 2011 21:20
Displaying only edges and not nodes of the grid in contour views val3312 FLUENT 1 May 26, 2009 03:27
