thrust and torque coefficient in rotating frame |
March 24, 2016, 18:26 |
Tansu
Rep Power: 12 |
I am getting confused while solving rotating frame problems in SU2. My results are becomes too far from experimental data. For example, I get C_T = 2.07 e-2 but the experimental data is around 80 times smaller than this value. I checked the flow.dat and solutions are correct, but coefficients are wrong. Do I have mistake in defining reference area or something ? My reference area is z-projection of the blade and my reference moment length is the span of the blade. Also i don't know that if SU2 considering solidity in the calculation of C_T and C_Q values. Do you have any ideas ? thanks in advance, Tansu |
March 28, 2016, 18:31 |
#2 | |
Heather Kline
Rep Power: 14 |
The console output will include the reference area calculated if the automated area calculation is used, and you can specify this area yourself if needed. The reference areas and lengths should match whatever is used in the experimental data you are trying to match. You should also check the MARKER_MONITORING value, it should contain all of the surfaces over which these values are calculated. |
March 28, 2016, 19:04 |
#3 | |
Tansu
Rep Power: 12 |
When the reference area is calculated automatically, the console output is as follows: "Area projection in the z-plane = 1.01", which is the true value of my blade area. Also I did Caradonna-Tung test case, and I tried to build similar .cfg file and create similar grid like 2 blade configuration etc. My marker_monitoring values are also correct :S I wonder if SU2 consider solidity in the calculations of coefficients? If yes, results looks normal, if no something looks wrong Thank you, Tansu |
March 30, 2022, 02:15 |
Sushil Nepal
Rep Power: 4 |
Hello Tsevine,
Can you please share your cfg file? I am trying to do something similar for high altitude environment but I am facing some problems so I wanna compare the cfg file. Thank You! |
wrong SU2 calculation for lift and drag coefficient for NAC4421 | mechy | SU2 | 7 | January 9, 2017 06:18 |
calculate the thrust and torque of a propeller in open water condition. | Alex song | STAR-CCM+ | 14 | August 3, 2016 12:54 |
Thrust and torque of a propeller | Alex H | FLUENT | 3 | July 1, 2016 18:00 |
Propeller thrust analysis | euclid | ANSYS | 0 | June 24, 2015 10:39 |
Propeller torque | Alex H | FLUENT | 1 | November 1, 2006 07:18 |
