Home > Forums > Software User Forums > SU2
Segmentation fault: 11
Old   February 26, 2016, 11:54
Default Segmentation fault: 11
HS Bruner
gncCFD is on a distinguished road
I am a newcomer to SU2. I am getting frustrated because I routinely get a "Segmentation fault: 11" error. I have attached an example of a very simple wing with standard NACA airfoils and modest amount of twist. The program seems to reach a solution to the aero problem, but fails after that. It creates the surface_flow.csv file, then fails before it can create the force breakdown file and the PARAVIEW plot files. The end result is a "Segmentation fault: 11". Seems like it fails when trying to merge the aero solution with the geometry.
My work-around to this so far has to make very slight arbitrary tweaks to the mesh density, but with no change to the physical problem. Through trial and error, I can get it to run all the way through to a normal conclusion. Seems like no matter what, if it can reach a solution to the aero problem, it should be able to create all the output files.
I am running the pre-compiled version 4.0.2, downloaded directly from git-hub, on Apple OS X 10.11.2, with Python version 2.7.10. Attached is copy of the standard output produced in file stdoutput.txt and my configFile, with extension changed to .txt The example included was only run for a view iterations and with a coarse mesh, just to keep the file size small. More iterations and finer mesh don't solve the problem.
gncCFD is offline   Reply With Quote
Segmentation fault when running dieselFoam or dieselEngineFoam in parallel francesco OpenFOAM Bugs 4 May 2, 2017 22:59
Segmentation fault when running in parallel Pj. OpenFOAM Running, Solving & CFD 3 April 8, 2015 09:12
Segmentation Fault w/ compiled OF 2.2.0 - motorBike example sudo OpenFOAM Running, Solving & CFD 3 April 2, 2013 18:27
segmentation fault when installing OF-2.1.1 on a cluster Rebecca513 OpenFOAM Installation 9 July 31, 2012 16:06
ParaView segmentation fault only for multiphase gwierink OpenFOAM 9 March 25, 2010 08:23
