February 24, 2016, 08:30 |
Small reisudal but solution do not converge
Jason Shih
Rep Power: 11 |
Hi,guys!
I'm using SU2(4.0.2) for CFD research, and I have some questions about the residual of SU2. In my case(M100 wing, Ma=0.8027, Re=11.31E6, AoA= 2.873), the residual(Res_Flow[0]) has already very small(-8) after 10000 iterations, but the force coefficients(Cl,Cd) have not converged. Is it the problem of the mesh or the setting of the configuration? Best regards, Jason Shih |
May 25, 2016, 08:14 |
#2 | |
Heather Kline
Rep Power: 14 |
Based on your plots it is not yet converged. The residual has reduced by less than an order of magnitude, generally we look for at least 4 orders of magnitude reduction (so, a log(residual) of -12 in your case). Tools like the multigrid, and CFL parameters may be useful in accelerating the convergence. |
converge, resiudal |
Converging the solution | aja1345 | FLUENT | 13 | June 15, 2022 00:46 |
CFL Condition | Matt Umbel | Main CFD Forum | 19 | June 30, 2020 09:20 |
solution converge problem | flow_CH | FLUENT | 0 | July 12, 2013 03:06 |
small numerical fluctuations in the solution | nandiganavishal | OpenFOAM Running, Solving & CFD | 4 | June 18, 2013 04:01 |
Naca 0012 (compressible and inviscid) flow convergence problem | bipulsaha | FLUENT | 1 | July 6, 2011 08:51 |
