Volume integration of Mach number for evaluating convergence |
February 14, 2016, 06:04 |
Mike
Rep Power: 10 |
Is it possible to implement a volume integration of Mach number in SU2 to evaluate convergence? I'm running a hypersonic inlet study and would like to know when the internal shockwaves have reached stable positions which isn't easy to determine just from the outputted residuals alone. I know I could plot the solution at regular intervals to manually check but I was hoping for an automatic way of doing it, possibly by outputting it into the history file. If not currently possible is this something I could easily implement into the code myself? Cheers. |
February 16, 2016, 05:07 |
Tim Albring
Rep Power: 10 |
Hi Mike,
you can do it similar to the way described here: http://www.cfd-online.com/Forums/su2...-variable.html You can compute the Mach number at a point by using Code:
su2double Ma = sqrt(node[iPoint]->GetVelocity2())/node[iPoint]->GetSoundSpeed(); |
convergence, mach, shockwaves, su2 |
Decomposing meshes | Tobi | OpenFOAM Pre-Processing | 22 | February 24, 2023 09:23 |
Low Mach number wing/body junction convergence | Zen | SU2 | 6 | May 3, 2019 04:51 |
foam-extend_3.1 decompose and pyfoam warning | shipman | OpenFOAM | 3 | July 24, 2014 08:14 |
AMI interDyMFoam for mixer | danny123 | OpenFOAM Running, Solving & CFD | 4 | June 19, 2013 04:49 |
same geometry,structured and unstructured mesh,different behaviour. | sharonyue | OpenFOAM Running, Solving & CFD | 13 | January 2, 2013 22:40 |
