February 12, 2016, 09:49 |
CA much lower than reasonable.
Brittany
Rep Power: 10 |
I am working on a case that is giving me answers I don't believe. The CFx value I'm getting out of SU2 is about 2.6. Using the rule of thumb of a Cd value of ~2 and calculating the CFx value given the largest cross-sectional area and Sref values, the Cfx should be closer to 13. Can you please take a look at my input file and see if there is some glaring error that I'm missing?
Thank you. |
February 12, 2016, 21:41 |
Francisco Palacios
Rep Power: 15 |
The input file seems OK. But, if I were you, I would run it without Multigrid. Could you please post the convergence history and some pictures of the grid? Have you check the y+?
Best, Francisco |
February 13, 2016, 10:12 |
Brittany
Rep Power: 10 |
My y+ values should be ok. I plotted it out in Paraview, and got values of 0.4 to 26 or so. Unfortunately I can't post pictures of the grid at this time. I will try without multigrid.
Thank you |
February 13, 2016, 11:07 |
Francisco Palacios
Rep Power: 15 |
Please remember that SA requires a y + <1.0 on the surface. a convergence plot would be useful.
Best, Francisco |
What's happening to my solution for lower relaxation factor | casesam | OpenFOAM Running, Solving & CFD | 3 | October 22, 2015 02:25 |
Temperature lower than possible in closed domain | Czarulla | Main CFD Forum | 1 | January 15, 2015 06:01 |
[snappyHexMesh] upper and lower patch for a 0_thick Membrane in a wind tunnel | hfs | OpenFOAM Meshing & Mesh Conversion | 7 | October 15, 2013 17:41 |
snappyHexMesh: cell lower corner instead of cell centre | andrea.pasquali | OpenFOAM Programming & Development | 4 | February 11, 2013 07:22 |
Lower heating value | Andrea | Siemens | 2 | July 30, 2007 08:19 |
